remove transmission spacer plate
Old Feb 19, 2023 | 11:54 AM
JoMa93's Avatar
Default remove transmission spacer plate
I am in the process of manual swap my xjr and I need to remove the spacer plate that sits between the engine and transmission. I have removed all the bolts I can see but it is still stuck in place. Is there something i have missed? or is it just a case of jently violence with wood and a hammer to knock it loose?
Old Feb 20, 2023 | 10:53 PM
someguywithajag's Avatar
There are two bolts that are bolted through the oil pan that attach to that spacer. Access is from underneath. No violence of any kind is required...good luck
JK_XKR
Aug 4, 2020 12:58 PM
catroad
Aug 8, 2017 05:10 PM
Reginald Adrian Hankin
E type ( XK-E )
Dec 29, 2016 06:34 PM
37driver
Nov 7, 2016 10:36 AM
Disco stu55
May 3, 2009 11:27 AM
