Repainting letters on coil cover and supercharger housing
Old Apr 3, 2017 | 01:24 AM
Qvhk's Avatar
Default Repainting letters on coil cover and supercharger housing
This seems a silly question but would like to know if there are any smart ideas repainting the embossed letters nicely. Tried using permanent marker before but the effect is not that good. Heat resistant paint is a must but I lack the artistic skills to do it.
Old Apr 3, 2017 | 05:06 AM
aholbro1's Avatar
If you want silver, just sand very lightly and carefully with a very fine grit.
If some other color, I'd spray the cover, mask the letters, and then re-spray the cover.
Much harder to mask "around" the letters.
Old Apr 3, 2017 | 02:27 PM
Jagboi64's Avatar
Or, given how the letters are raised, you could probably paint it with a very stiff foam roller and not have to mask it off.
Old Apr 3, 2017 | 02:38 PM
al_roethlisberger's Avatar
That was my eventual plan, something like a rubber ink roller to apply the paint to the raised letters.
Too bad the coil cover isn't aluminum like the intake duct, as you could take a sander and make the letters a brushed aluminum finish.
Old Apr 3, 2017 | 06:34 PM
michaelmedina2005's Avatar
i carbon fiber wrapped mine with 3m di-noc
Old Apr 3, 2017 | 06:35 PM
also the cap
Old Apr 4, 2017 | 10:13 AM
Qvhk's Avatar
Maybe I can just cover the surrounding of the raised letters with clay mask, or cover the entire area with self-adhesive and elastic plastic sheet (like michaelmedina2005 did) and then cut the raised letters out, and then spray, or just simply wrap the letters? Hope the right heat-resistant material and tools are available.
Old Apr 4, 2017 | 11:26 PM
StuG's Avatar
I used a paint pen (edding 750 - A paint marker with a good heat resistance - edding.com) on the raised lettering of my supercharger over a year ago and it has held up quite well.
Old Apr 5, 2017 | 06:52 PM
the material on the letters bubbled,from the engine bay heat,i had even installed 1800 degree lava wrap underneath,so i cut it away,to show the red lettering,hopefully problem solved
Old Apr 5, 2017 | 10:16 PM
Don B's Avatar
One idea would be to use frisket, or masking fluid, brushed onto the background area around the letters and allowed to dry. After spray-painting the letters, just peel away the frisket:
Dick Blick Friskets & Masking Fluids
Cheers,
Don
Old Apr 5, 2017 | 10:42 PM
great idea,tnx Don,i already have it in my amazon cart
Old Apr 6, 2017 | 01:32 AM
on edge's Avatar
Hi I used mask tape along bottom and top of wording then used an artist fine brush and carefully put thin layer of grease inbetween lettering. then spayed with high temp engine red . figetty but worked well .Cheers Ray.
Old Apr 6, 2017 | 01:36 AM
on edge's Avatar
Meant to say when the paint is dry you can wipe away the grease.
Old Apr 6, 2017 | 03:11 AM
One of Admin JimC64's sons did a great job repainting the lettering on the covers of his X-Type.
I can't find a post with photos and details of the technique so I've sent Jim a PM about this thread.
Old Apr 6, 2017 | 06:28 AM
Thanks Graham, have a few but as usual can only find one or two
Here's Jamie's on his X type
Here's mine on my XJ
Both were done using Ferrari Red high temp resistant caliper paint
A small tin off Ebay was only around £6 iirc
There was no real secret or tips n tricks, just a little time, a small brush and a steady hand for pretty good results which have held up very well, as good as the day they were done
Jim
Old Mar 26, 2020 | 09:27 AM
X300exec's Avatar
Steady hand and some patience
Old Mar 27, 2020 | 12:19 AM
XJR-100's Avatar
Does anyone know of a source for the Jaguar decal? Have tried many suppliers (incl. Welch which stated in stock) to no avail.
Eric.
Old Mar 27, 2020 | 02:38 AM
X300exec's Avatar
No sorry ,mine has raised lettering so I didn’t need it
