Replacement chip key
Old Sep 22, 2023 | 11:28 PM
willbot's Avatar
Default Replacement chip key
Has anyone found a programmable substitute that works okay? Or is it only possible to use the original chip?
Old Sep 22, 2023 | 11:31 PM
willbot's Avatar
I've lost my keys but I did save a photo of the key on each side, which I can use to reverse-engineer the key code
Old Sep 23, 2023 | 08:42 AM
xalty's Avatar
id13 8 cut blank
same as early x308
Old Sep 26, 2023 | 04:50 PM
willbot's Avatar
Thank you is it possible to program in the new key on the 1996 xjr6 without the old one present??
cheers
Old Sep 26, 2023 | 07:44 PM
motorcarman's Avatar
No idea where you are but NORTH AMERICA did NOT start the RFID keys until 1998.
Might want to tell us where you are located?
Old Sep 26, 2023 | 07:47 PM
xalty's Avatar
cheers
yes with ids
Old Sep 26, 2023 | 08:54 PM
willbot's Avatar
I'm in NZ but the car was imported from the UK, it's a 1996 xjr6
Old Sep 26, 2023 | 08:56 PM
willbot's Avatar
Originally Posted by xalty
yes with ids
Ah thank you, will see if any nearby mechanics can do it
Stephen Harron
XE ( X760 )
Feb 4, 2020 01:49 PM
Sovejag13190
Sep 22, 2018 05:46 AM
Djm61
Sep 14, 2017 07:33 AM
mehul0623
US Western
Dec 23, 2014 07:50 PM
ragekage23424
Jan 15, 2013 02:12 PM
