replacing climate control module
Old Apr 2, 2024 | 05:26 AM
Spud Maat's Avatar
Default replacing climate control module
ok so my question is, is a x308 and x300 climate control module interchangeable?
they physically look the same, connectors look the same and part numbers are very similar, LNA7600A# for the X300 v LNC7600A# for the X308 model.
the reason i ask is i am pretty sure mine is worn and in need of replacment.
i am getting an intermittent issue where the vent controls become inoperable and/or the foot/windscreen vent button flashes on and off.
this comes and goes.
i have run the diagnostics and the only error codes i had was 23 from when i had low gas but that is now sorted.
when i run the self test all the vents switch and there is no issue with any function.
so i am pretty sure that the module is on its way out.
i have taken apart and cleaned the switchpack and all the switches work just fine.
Old Apr 2, 2024 | 07:22 AM
Parker 7's Avatar
They are the same Denso A / C system minus the center vent thumbwheel pot but ..........................................
Part # X and Y
Item # 2 for X300
Genuine Air Conditioning And Heater Unit For Jaguar Xj 1995 - 1997 (from 720125 To 812255) (x300) Classic | Jaguar Land Rover Classic Parts
MNA6440AD
Item # 2 for X308
Genuine Air Conditioning And Heater Unit For Jaguar Xj 1998 - 2003 (from 812317 To F59525) (x308) Classic | Jaguar Land Rover Classic Parts
LNC7600AF
Same for outside US and Canada models
LNC7600AF
Redjags
Oct 24, 2022 06:46 PM
Bluefish001
Oct 8, 2022 02:07 PM
1927
May 20, 2018 11:18 AM
'05 STR
24
Nov 7, 2015 11:34 AM
Dirk Bailey
22
Jan 27, 2013 07:22 AM
