Replacing front suspension
Hey Guys
Thank you for responce:=)
Had the balance of the front Wheels checked at the local shop.
Slight imbalance, changed the weights on the Wheels.
Tested again with 130 km/t and now no vibration.
Ok so easy fix. Next long ride will show. But hopefully ok.
Best
Papelione
Best
Papelione
I bought this FoxHunter 6 Ton Tonne Hydraulic Garage Workshop Shop Press Floor Standing Blue | eBay
pushes 6 of the bushes easily, the large flange lower front is still a subject of study ;-)
I have also changed the V mounts without and engine brace/support. You only need that if you remove the crossbeam altogether, otherwise you can lower a side at a time on the jack and get the V mount in and out as long as the car body is on stands. Fit he crossbeam screws first before jacking back up, you will need a long shank Torx 40.
Bcrary3
Oct 27, 2015 09:17 PM
