Replacing front suspension
Old Jun 16, 2016 | 06:48 AM
  #41
Papelione's Avatar
Hey Guys
Thank you for responce:=)
Had the balance of the front Wheels checked at the local shop.
Slight imbalance, changed the weights on the Wheels.
Tested again with 130 km/t and now no vibration.
Ok so easy fix. Next long ride will show. But hopefully ok.
Best
Papelione
Old Jun 20, 2016 | 02:22 PM
  #42
6sabre's Avatar
I bought this FoxHunter 6 Ton Tonne Hydraulic Garage Workshop Shop Press Floor Standing Blue | eBay
pushes 6 of the bushes easily, the large flange lower front is still a subject of study ;-)
Old Jun 21, 2016 | 04:15 AM
  #43
Papelione's Avatar
Default Press
Good to hear.
With the price I paid to have em pushed out.
I could have bought a nice press. Next time I will do that.
Best regards
Papelione
Old Jun 23, 2016 | 07:05 AM
  #44
6sabre's Avatar
The front lower bushes proved a problem, in the end I had to cut off the flange with a chisel. The issue is supporting the arm while you press out and the flange stops that.
I have also changed the V mounts without and engine brace/support. You only need that if you remove the crossbeam altogether, otherwise you can lower a side at a time on the jack and get the V mount in and out as long as the car body is on stands. Fit he crossbeam screws first before jacking back up, you will need a long shank Torx 40.
SouthernGypsy
Nov 3, 2015 09:12 PM
Bcrary3
Oct 27, 2015 09:17 PM
Jagzzz
Oct 26, 2015 11:46 AM
Doug Dooren
Oct 20, 2015 06:43 PM
LnrB
Oct 18, 2015 10:53 PM
