R's Resonant Rear Rumble Rationalized!
Old Jul 20, 2014 | 06:58 AM
95XJRBlack's Avatar
Default R's Resonant Rear Rumble Rationalized!
My 1995 XJR has a low resonating "rumble" that only starts when the car approaches 37mph peaks at 40mph and quiets down around 43mph. It's annoying because this is the typical speed for around-town driving. I eliminated tires and wheel balancing as a root cause and am now focusing on exhaust system mounts/bushing.
A Brit car expert/mechanic friend told me that cars tend to have a unique frequency at the chassis shows resonating vibration (that has to be addressed during design/testing) and for the X300 40mph may very well create this frequency...and therefore exhaust vibration made audible by bad exhaust bushings.
Funnily enough he told me MGBs' resonate at 60mph, a common highway cruising speed.
I am going to explore this further with my XJR, but thought I would share some info that was new to me!
Old Jul 20, 2014 | 01:37 PM
AL NZ's Avatar
check driveshaft hanger bearing...
Old Jul 20, 2014 | 08:20 PM
jvitez's Avatar
Does it increase in intensity when you apply the throttle pedal, and decreases when you back off the gas? If so, +1 on the hanger bearing. I replaced it on both my Dodge Ram Cummins and my XJR (what haven't I replaced in the undercarriage.....) with same symptoms.
Old Sep 13, 2014 | 06:39 AM
95XJRBlack's Avatar
Took the XJR to my friend's shop (shameless plug: Sports Car Warehouse) and replaced the drive shaft carrier bearing and expansion joint. Problem solved.
Next for replacement transmission mount and missing exhaust mount.
Carrier bearing before replacement
Bad transmission mount
My car among some older British relatives!
Old Sep 13, 2014 | 12:04 PM
Don B's Avatar
95XJRBlack,
Thanks for the follow-up post and the great photos!
Cheers,
Don
FrickenJag
Jun 16, 2025 02:15 PM
H20boy
Dec 24, 2024 03:23 PM
Daim
Nov 28, 2016 09:28 AM
Nigels420G
Mark V - X 420G
Sep 17, 2015 10:29 AM
AtholC
Sep 9, 2015 09:07 PM
