Running light and Taillight staying on!!!
Old Jan 10, 2022 | 10:37 PM
JStatic's Avatar
Default Running light and Taillight staying on!!!
What’s up everyone, I just purchased a 1997 Jaguar XJR6, body and paint are good, drivetrain is solid with 173k miles on it but there is one issue that has got me. The running lights stay on when the car is off. I can turn the lights off when the car is running but as soon as I shut the car off the lights will turn on again. I’ve checked all the doors and made sure that they are closed, trunk closed, yet lights still stay on.
Has this ever happened to anyone before? Any advice would help, I would like to drive the car around without having to disconnect the battery every time I leave it parked.
I also checked fuses but everything checked out fine.
Thanks in advance
Old Jan 11, 2022 | 01:34 AM
Parker 7's Avatar
If you get to the point of changing the exterior lamp control module the 97 has a part # change with respect to the last 6 #s of your VIN #
https://parts.jaguarlandroverclassic.../brand/jaguar/
There is the front courtesy lights that should come on in exiting the car
See Youtube video and it might be in there
Old Jan 11, 2022 | 01:56 AM
JStatic's Avatar
Anything helps, thanks for the reply.
Old Jan 11, 2022 | 03:19 AM
Parker 7's Avatar
Is it the small bulbs in the lower portion of the lens of only 2 front headlamps ?\
A white Tail light may also be included as a courtesy light
Old Jan 11, 2022 | 03:28 AM
JStatic's Avatar
Yes that’s it, it’s the bulb on the lower portion of the lens. Also the taillights stay on.
Old Jan 11, 2022 | 06:50 PM
Parker 7's Avatar
Is it the white back up light or a red running light different then the red stop light ?
Old Jan 11, 2022 | 06:54 PM
JStatic's Avatar
It’s the red running light that’s staying on
Old Jan 11, 2022 | 07:13 PM
Parker 7's Avatar
Ok
So the rear red running light would not be expected
The courtesy lights are on a timer , does the rear red running light go out after a certain time along with the front lower small white bulb in the headlights ?
This could also include the very lower door lights but I'm not for sure on that as they may be door open switch dependent
Old Jan 16, 2022 | 09:27 PM
JStatic's Avatar
Problem solved! It was a faulty light switch. Swapped it out with a used switch from the wrecking yard and lights are functioning properly now. Now to figure out why my steering wheel tilt is now working.
Old Jan 16, 2022 | 10:46 PM
Parker 7's Avatar
The tilt has a position sensor attached to a gearbox that binds from old grease and drags down the motor and whole mechanism
The extension has a shaft that shears and has to be replaced and harder work
But I get the 2 directions mixed up in my head
Fuse ?
There was a Jaguar TSB to put in a more powerful motor, but you can clean out the old grease and put in new grease
10-12 (jagrepair.com)
The sensor gear box is on the very lower portion of the column, and you can see it if you crawl under there and just clips on
But on reinstallation it has to be clocked so don't remove it yet and tinker with it
There is a clocking process
See the pics in this thread and you do not need to remove the motor just the black gearbox / sensor attached
Steering wheel tilt and reach explained - Jaguar Forums - Jaguar Enthusiasts Forum
Editing
Old Jan 20, 2022 | 01:38 AM
JStatic's Avatar
Fuse ?
Editing
It was a fuse, looks like the previous owner tried using a 5amp fuse instead of a 10amp, swapped it out with the correct amp and presto mirror and tilt are working again. Now to replace the radio since the capacitor on the original blew out and corroded the circuit board.
Also FYI the car has sat for over a year, looks like the previous owner didn’t have much luck sorting out the bugs or just neglected it. I will need to change all the fluids and flush the fuel system, also do some major color sanding and polishing to bring it back to showroom condition, overall the car is in great shape and drivetrain is healthy.
I also want to add that buying a decent test light has been very helpful.
thanks for all the help, I will keep posted on progress.
Old Jan 20, 2022 | 08:56 AM
Parker 7's Avatar
There is a TSB on upgrading the fuse sizes that are different then the original values
There was a thing about counterfeit fuses that will not blow but limit the current flow based on using the incorrect metal conductor
It can be found here and your TSB # is 15 - 16
JagRepair.com - Jaguar Repair Information Resource
Diddion
Aug 21, 2025 06:40 PM
Todd Wiens
Oct 6, 2021 04:49 PM
jonijoni
Oct 10, 2019 09:58 AM
XJ6Ambition
General Tech Help
Dec 29, 2011 10:39 AM
perfectphoto
Oct 27, 2011 01:50 PM
