Sagging nose on x300 XRJ
Changed out the sway bar end link, strut top mounts, and control arm bushings. Now the nose of the car is completely compressed. Adaptive suspension, not air. Springs were in good shape and the strut seemed fine as well. From my understanding springs affect ride height not the strut. Did I maybe over tighten the bolts and the spring can't push it back up?
Which year as 4 door sedan with supercharged inline 6 engine ?
XJR X300 as model on this forum section,
Adaptive suspension ?
There is a complication of adding " Andy Links " to the sway bar ends beyond factory configuration'
Both ( 2 ) isolators installed on top of front shocks for each side to total 4 isolators or donuts ?
Item # 8
Genuine Road Spring And Damper-front For Jaguar Xj 1995 - 1997 (from 720125 To 812255) Classic | Jaguar Land Rover Classic Parts
and item # 7
Genuine Anti Roll Bar And Lower Fulcrum Tie For Jaguar Xj 1995 - 1997 (from 720125 To 812255) Classic | Jaguar Land Rover Classic Parts
Item # 8
and item # 7
Not sure what you mean by “ completely compressed” but there is not meant to be any ride height adjustability built into the front suspension. The X308 XJR had “CAATS” adaptable suspension, but that also would not affect ride height.
There is no “strut” as such, just the shock absorber, but it plays no part in setting ride height.
The spring May look in good condition, but they do sag over time, which would cause reduced ride height. Search the forum regarding front spring removal, as it requires a special tool, and is not for the feint hearted!
xjrjag
Jul 2, 2020 01:40 PM
WayneHWilson
Jul 24, 2018 04:10 AM
