Shock Absorbers
Old Feb 25, 2026 | 06:05 AM
Da Roadrunner's Avatar
Default Shock Absorbers
My XJR6 has green colour Bilstein shocks that need replacing. While I am at it I would like to improve the ride. Is there anything better than the original Bilsteins?
Old Feb 25, 2026 | 11:57 AM
Parker 7's Avatar
This from an old Bilstein's catalogue so you have an original number to work from
Your XJR is on the very bottom and notice the harder B6 rating ( ? ) , first 24 number is the front then rear
Motorcarman had a suggestion on the front lower shock attach point bushing to be replaced ( does not come with shock ) You can see daylight through if you look , It would give a rattle on ride
He says there are substandard manufactures that do not last long
Xj 1995 - 1997 (from 720125 To 812255) (x300) Classic / Wishbone-upper And Lower | Jaguar Land Rover Classic Parts
This will be item 13 called Damper Bushing , Jaguar # CAC75851
Andy is offering a front sway bar link upgrade ​​as you already on the XJR have the larger diameter sway bar
There is on the rear the more solid X308 crossbar that can be and has many times substituted ( can be done without rear suspension removal and just " slipped in " ) there is a little hardware difference
See item 13 on this X308 , Bushed differential strut part # MNC3713AA for the softer bushing and MJA3713AD for the harder
Xj 1998 - 2003 (from 812317 To F59525) (x308) Classic / Wishbone Assembly | Jaguar Land Rover Classic Parts
pcolapacker
Jun 5, 2024 08:26 PM
jcb-memphis
Apr 7, 2022 04:45 PM
Jose
Oct 7, 2021 01:15 PM
loftymk1
Apr 8, 2017 04:21 AM
viscoussquirrel
Apr 24, 2010 10:47 PM
