sparkplug change
Old Aug 11, 2010 | 12:28 PM
jagman96's Avatar
Default sparkplug change
i was going to do a sparkplug change myself. how hard is it to change the wires and plugs on the 96 xj6? where exactly are they located?
Old Aug 11, 2010 | 01:11 PM
JagScott's Avatar
It looks like they are under the intake manifold. I just got mine and was scratching my head over it too.
Old Aug 11, 2010 | 01:19 PM
Doug's Avatar
Remove the cover on the top of the engine that says "Jaguar" on it and you'll see the coils. Under each coil is a spark plug. Unplug the coil, remove the two bolts, and wriggle it off the spark plug. Repeat 5 more times :-)
Old Aug 12, 2010 | 05:18 AM
jagman96's Avatar
Default sparkplugs
took my plugs out, and they looked pretty good. but the gap was .031. i think it calls for .035 gap. so i gapped them to .035. will i see a difference?
Old Aug 12, 2010 | 05:54 AM
sparkenzap's Avatar
I bet not, but gapping to the correct setting is still good for optimum performance.
Old Aug 13, 2010 | 06:24 AM
Oubadah's Avatar
Make sure you use Champion RC9YCCs. Yes, gaps are 0.035 inch (0.09mm).
Old Aug 13, 2010 | 04:41 PM
bhmaxjag's Avatar
actually rc12's are now being used in place of the rc9's per Jaguar recommendation. I just did my tuneup using the 12's (12's came out of mine as well)..and she runs like a top
Old Aug 13, 2010 | 07:45 PM
Oubadah's Avatar
I thought they were only for those having idle issues. (except blower cars, where they're standard?)
Old Aug 14, 2010 | 08:54 PM
bhmaxjag's Avatar
Possibly, but I have access to Alldatapro and under the TSB it says it applies to all cars, not just those with idle issues. So if you were to go to a Jag dealer to have the tuneup done, I am 99% positive they would throw the rc12's in the car even if rc9's came out. But hey if rc9's work fine for you there is no need to change them (but why not use the 12's? They're the same exact price). With my discount at work (I work for an auto parts store) I got 6 plugs for 9 bucks and change including tax. Champions are dirt cheap and I'm so glad old british cars love them
Old Aug 24, 2010 | 03:03 PM
hawaiianjag's Avatar
hey there i'm getting ready to throw in some new champion rc12ycs
I haven't changed plugs on a jag before anyone know the proper torque i should tighten the plugs, I know tightening too much is a big no no
perhaps you could enlighten me?
Aloha
Old Aug 24, 2010 | 04:30 PM
jagman96's Avatar
i have never torqued sparkplugs, just snug them nicely. but others may chime in
Old Aug 24, 2010 | 09:30 PM
someone that has the repair cd should have the torque specs for the plugs. Im eager to try my new torque wrench out haha
Old Aug 24, 2010 | 10:10 PM
Doug's Avatar
Nor have I. Finger pressure only on the ratchet until they're seated then about 1/8 turn more, I reckon. Ten ft/lbs maybe?
Old Aug 25, 2010 | 03:38 AM
I also use the 'Doug' method. Always have done.
I guess that we are all doing this incorrectly.
The only info I could quickly find was in a Haynes for a 94 so you might want to do some checking yourself.
17 - 21 lbf/ft
In the wrist, you have 'T', 'BT', and 'VBT' and you get a feel for them. I suppose it might be an exercise to retro check these against a torque wrench.
Of course head bolts = torque wrench.
Old Aug 26, 2010 | 01:57 AM
thanks for the help everyone many mahaloz
Jandreu
Jun 30, 2022 03:10 PM
Scarecrow
Mar 28, 2016 03:17 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Gerard Radimaker
Sep 13, 2015 10:33 AM
teacoff
Sep 10, 2015 08:25 AM
