Sport mode not engaging
Old Feb 4, 2017 | 08:35 PM
goodgame's Avatar
Default Sport mode not engaging
Can anyone offer a suggestion as to why my SPORT mode in my 96 xj6 (300) seems to be non functional even tho when the switch is hit it lights up on the dash..?
Old Feb 5, 2017 | 10:46 AM
motorcarman's Avatar
Why do you think that Sport Mode is disabled.
You only notice it during 'spirited driving'. Otherwise the gearbox shifts normally.
Old Feb 5, 2017 | 11:15 AM
goodgame's Avatar
i guess the best way to describe it would be to say that I'm not feeling the kickdown as I would feel it in my other x300
Old Feb 5, 2017 | 11:30 AM
al_roethlisberger's Avatar
Kickdown and sport mode are two different things, so just checking we are all talking about the same thing...
The "sport" mode simply keeps the transmission in a given gear for a slightly longer time (higher RPM) which adds a little top end RMP "zip" in each gear at the sacrifice of economy. In "normal" mode the transmission shifts earlier to increase economy and comfort.
If your car isn't downshifting (kickdown) on full throttle that is something different, and for that issue check out this recent thread for some info:
https://www.jaguarforums.com/forum/x...l-stop-176078/
Old Feb 5, 2017 | 01:53 PM
goodgame's Avatar
yeah I'm not feeling that zip per say.. No noticeable change whatsoever..
Old Feb 5, 2017 | 02:02 PM
goodgame's Avatar
And thanx, I'm going to look into the kickdown switch as well..
Old Feb 6, 2017 | 03:21 PM
To be honest, it's pretty minor although feels slightly peppier.
Old Feb 7, 2017 | 03:02 PM
goodgame's Avatar
i know right.. It's just that I'm getting absolutely nothing.. That's why I was wondering could there be a relay or maybe module I'm not knowing about
Old Aug 7, 2019 | 05:08 AM
cdma's Avatar
Seems that I am not the only one with this problem. I appears that this may be a difficult one to troubleshoot
Old Aug 8, 2019 | 07:32 PM
Lady Penelope's Avatar
Ground point 10 goes through the troublesome BT4 connector above the fuel tank at pin # 12 not shown in this pic
See labeled pin # 13 on the pics top edge
# 12 will be just below # 13 and is Black / Pink color coded , The BT4 connector is mounted sideways . This connector type is used on 4 other areas of the car LS3 , RS3 ect
Do not remove this BT4 connector yet , A pain in the *** to get right and not damage
The car will not start with this BT4 connector removed
As installed the locator pin # A ( heavy gauge wire ) in the top left of the car location is X in color
See page 41
http://www.jagrepair.com/images/Auto.../jagxj1996.pdf
