squeaking noise alternator belt
Old Apr 9, 2018 | 08:26 PM
xjfourty's Avatar
Default squeaking noise alternator belt
Hello today I jump started a Friend GOLF using my Jag.
Engine turned on, connected the battery poles. Everything ok so far.
Before my friend turned the engine of his car on I pushed slightly on the accelerator to give more rpm and more power to the battery, and at the same moment I head a squeak sound at my alternator. It never happened before. Neither it happened after disconnecting the battery poles.
Did It happened because of the higher load on the alternator probably ?
Any hints? Should I replace the alternator belt ?
Old Apr 9, 2018 | 10:18 PM
Lady Penelope's Avatar
Yes , there is a rotational resistance to a high alternator load
No , if you tighten up the alternator belt too much you risk limiting the service life of your alternator and water pump bearings , belt being cheap and easy to replace .
If you jump start a car , better off letting your car charge up their battery for 15 minutes first . Your car . Don't take one for a VW .
digimurda
Mar 15, 2017 10:31 PM
JCHouston
Jun 10, 2014 06:23 PM
Double Tap
Sep 21, 2010 03:03 AM
davies
Aug 25, 2010 09:57 AM
adam12hicks
Jan 24, 2009 01:49 PM
