Stalling after warmup
Old May 25, 2011 | 03:46 PM
Stanpittman's Avatar
Default Stalling after warmup
I have a 97 XJ6L with a problem I have not been able to solve. The car stalls after warmup. I've replaced the crank position sensor, spark plugs, tested fuel pressure and nothing has changed. At times before it stalls all warning light in the cluster light up. At other times when I starts to studder the mil light come on and off. Also I noticed that when it stumbles the fuel pump relay clicks like it's losing its ground from the ecm. Any ideas would be appreciated.
Old May 25, 2011 | 11:22 PM
Japthug's Avatar
Hi. It might be electrical problem, not the sensors. If you installed any aftermarket electrical parts, inc. radios, maybe you could make sure if every ground point is tightened properly. If not, the problem like yours occurs sometime. hope this helps.
Old May 26, 2011 | 03:29 AM
Heard this before elsewhere, many issues of the same consequence, and it was found to be the ignition coil/s breaking down and "back feeding" the system, and dash lights flickering, ECU doing stupid stuff, and once the coils were replaced all was normal again.
I know they are NOT cheap, but that's life with these coil over spark plug systems.
Somone with a tune up scope machine, and the knowledge to use it correctly, should be able to pick up which coil.
Old May 26, 2011 | 07:40 PM
You hit the nail on the head. I checked it out this morning in the shop with the lights off and number five ignition coil was flashing like crazy. I replaced the coil and the car runs perfect. Thanks
Old May 27, 2011 | 07:04 AM
Sweet.
Bloody simple cars we got here, hahahaha.
Where were they in 1968 when I first got Jaguars in my life??, oh well life goes on.
kingdom worker
Nov 14, 2020 03:47 PM
JaguarSV8
Oct 1, 2015 01:58 AM
LnrB
Sep 29, 2015 12:54 PM
Mark SF
Sep 28, 2015 01:51 PM
shootingbrake
Sep 23, 2015 10:54 AM
