Steering Column Installation
Old Mar 8, 2011 | 05:18 PM
JackJ's Avatar
Default Steering Column Installation
I am trying to reinstall my a steering column in my 1995XJ6. How in the world do you get the spline at the end of the column into the collar at the floorboard? It came out so easy. It does not seem to want to go back.
Thank you again for all the help!
Old Mar 9, 2011 | 08:50 AM
JackJ's Avatar
Just for future reference, if you use a screwdriver to spread the collar a bit it will receive the tip end of the column and the the splines. Then if you go under the car and tap with some kind of a non marring blunt object you can get the collar to slide up over the end of the steering column. You must mount the column firmly to the car the forward and aft mounts so that it is stationary as the collar slides onto the splines. This worked for me and I was able to drop the securing screw into place.
If anyone has any other methods I would be glad to know them too.
H20boy
Dec 24, 2024 03:23 PM
2001 White XJ8
Feb 25, 2021 05:02 PM
kevinl
Oct 31, 2019 06:15 PM
AL NZ
Sep 4, 2015 08:39 PM
laserguy
Sep 3, 2015 02:02 PM
