steps to install ecu in 96 vanden plas
Old Jul 29, 2011 | 12:02 PM
mtotrainer's Avatar
Default steps to install ecu in 96 vanden plas
I need to install another ecu in my vdp. I have disconnected the battery ground and then reinstalled the ecu including the ground wire.Did I miss anything ,as The car turns over but does not fire.
Old Jul 29, 2011 | 12:56 PM
Straight6DOHC's Avatar
I don't think you missed anything. What are the parts numbers and which car (engine size and transmission type) did the new ecu come off? Also, why did you feel you had to swap the ECUs?
Old Jul 30, 2011 | 07:17 AM
mtotrainer's Avatar
I took the car to a local jag shop as it would not start.It would turn over but not fire,everything else seemed towork so this tech installed a used ecu# LNA1410VD/102.The car only runs on 4 cyls now though. I think its not the right box,but can't seem to find out which computer I should be lookig for as there is no sticker in the trunk under the spare tire.I have been told that what I need is an LNA1410AH but what those last 3 digits are is a mystery. Can anyone help,as this has been going on for 13 months now,and I can't drive my beloved jag.
Old Jul 30, 2011 | 07:19 AM
mtotrainer's Avatar
Sorry straight6dohc,The car is a 1996 XJ6 vanden plas 4.0 inline 6 thx...Jamie
Old Jul 30, 2011 | 08:19 AM
motorcarman's Avatar
This is a U.S. TSB recall but it has some info and part numbers that might help with identifying the part you need.
bob gauff
File Type: pdf
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
rusty37
Apr 5, 2020 07:40 PM
eurotire
Sep 18, 2015 07:27 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
