Stereo installation question
Old Dec 30, 2018 | 12:54 PM
96x300's Avatar
Default Stereo installation question
I just ordered the only stereo install kit I could find currently available, from the UK. It includes the wiring and fascia piece so I don't have to hack up the wiring.
My questions being this.. I'm not previously experienced with Jaguars and my stereo and disc changer were missing when I bought the car. When I was searching on ebay I found a listing for the wiring adapter only ( may have been for xjs only), and there was a photo and directions showing a small section of wiring between the car's harness and the radio itself. What is this called, what is it's purpose, and do I need it when installing an aftermarket head unit? I just want to know if theres a missing piece I need to locate before filling the hole in my dash.
Old Dec 30, 2018 | 01:16 PM
Lady Penelope's Avatar
I'll have to get back with you , get to rake leaves now
This is the original wiring for the standard and premium set up with the external final amplifier and CD player you mentioned
If you had the standard setup you will have the 8 speaker wires coming from the head unit
They use the same head and connector but the difference is the speakers are driven with the final amplifiers contained in the head and the 8 wires in the connector or a round tan cable that goes back to the rear final amplifier and no 8 wires from the head
Both installations have a black round connector plugged into the left most side other then the round antennae on the right side
Old Dec 30, 2018 | 01:28 PM
96x300's Avatar
Thanks for the pics. Here's the photos from the plug adapter that said it was only for XJS that had me confused. To clarify this is Not what I ordered, I ordered the kit and stereo in the original post.
Old Dec 30, 2018 | 02:27 PM
hard to see in the top pic if it has the 4 pins on the top row on the left side and 5 pins on the right side
This is looking at the original stereo head as it is installed but looking at it from the captain sitting in his seat perspective
The adapter harness looks close as you need this to plug into the original car side connector
The concern is if you have the 8 speaker wires in the original car side connector
Otherwise the speaker wires originate from the trunk from the premium set up external power amplifier mounted in the trunk
Old Dec 30, 2018 | 05:26 PM
96x300's Avatar
I do not believe that I have the premium sound as I do not have the rear subwoofer and there is a bracket where the cd changer was as well as the wiring, but there is no evidence of an amplifier having been to the left of it as I've seen in pictures. I just wanted to make sure i'm not missing a piece of factory wiring, that's needed. Is that "modular harness" shown in the ebay sellers pics for the 96 XJS plug specific to the XJS, or something only needed for the factory stereo? The section with the black box in-line with the yellow wire is what I'm concerned with.
Old Dec 30, 2018 | 06:06 PM
The black box in the pic could be a noise suppressor if the 3 wires go into the Batt labeled positions
The X300 does not need this as there is a suppressor mounted below and to the left of the alternator
Or telephone equipment if going into the 3 Tele positions
Editing while I put the leafs to the curb
Old Dec 30, 2018 | 06:45 PM
96x300's Avatar
Okay thanks! That's along the lines of what I was thinking as well. I will post on how everything goes when everything comes in and gets installed.
Old Dec 30, 2018 | 07:15 PM
Have you looked into the speaker condition as the originals will most likely have the inner cone to outside diameter foam rotted away and sound bad
The originals can be repaired easily yourself very cheaply
Where did you find that brand new connector and pigtail with the wires never spliced
looks awful pretty as I left a used one behind at a salvage yard
Old Dec 30, 2018 | 07:25 PM
96x300's Avatar
I haven't checked the condition of the speakers yet, I was just going to install the head unit and see if they work. I have to research proper removal/installation of the door panels and although theres a DIY download, I seldom have good internet access via computer and do most everything on my phone without the aid of 4G.
I'm partial to a good set of Clarion speakers myself, for the cost they tend to exceed my expectations.
Old Dec 30, 2018 | 07:56 PM
The originals are a 3 mounting holes as most are 4 as I understand
I'll type out door panel removal on this venue if needed otherwise the speakers sound rattley
Old Dec 30, 2018 | 08:26 PM
96x300's Avatar
Oh okay, well I should be able to work out the mounting if I decide on aftermarket speakers vs repair. If it's not too much trouble I could use the panel instructions as I have issues with my driver's door as well ( panel loose at bottom, inner handle not working). Always so much to do and so little time!
Thanks for all your help!
Old Jan 5, 2019 | 09:59 PM
Jupgrade1's Avatar
So do you need the wiring harness for any aftermarket radio or just this specific one?
Old Jan 6, 2019 | 07:47 AM
I am personally staying with the factory head so I have not purchased a needed adapter to make a modern head work
You would have to determain the modern heads connector type first
So it's a cart before the horse thing , but he has ordered the items and will find out soon
In the case where you can't find a adapter that that fits both ends you can direct splice on the wires with the new heads oigtail
The wiring schematic for the 96 X300 is below on page 222 , 225 , and 228
Notice there are 2 options , one where the 8 speaker wires come from the head up front or the premium where it uses the exact sane head but uses a separate power amplifier in the trunk where the 8 + speaker wires come from
A way you can tell is if it has the CD player mounted in the trunk , The head will have the markings regardless if you have the CD player
http://www.jagrepair.com/images/Auto.../jagxj1996.pdf
Old Jan 6, 2019 | 08:15 AM
[QUOTE=Lady Penelope;2009969]I am personally staying with the factory head so I have not purchased a needed adapter to make a modern head work
Old Jan 6, 2019 | 10:10 AM
96x300's Avatar
As far as I know the wiring adapter I ordered is for any head unit, and the kit is not necessary since the dash opening is 1 din and the wiring can be spliced. The fascia just helps fill the irregular opening for the stock head unit for a more "factory" look, and the wiring harness should keep me from having to cut off the factory plug, allowing for a cleaner installation.
​​​​​The fact that you can install a radio without the kit is probably why it's hard to find, plus the relatively small market for a model made 20+ years ago for a 3 year period.
I ordered that particular head unit because it allowed me to purchase it and the kit for under $100 which I was sent as a gift and using for my budget. It also has USB/aux which was a requirement since I keep the majority of my music on a flash drive.
It should be here within the week so I will lwt everyone know. The head unit came in Friday and looks nice.
Old Jan 6, 2019 | 10:53 AM
aholbro1's Avatar
That wiring jumper allows you to plug the car's harness into most any DIN-standard head unit without cutting wires. If you happen to have the premium sound system fitted originally, you'll still find the jumper harness useful, but you'll have some additional work ahead of you, as well. SInce your head unit and CD changer were missing, I'd reckon any amp mounted alongside the CD changer in the boot would've also been scavenged. Check your rear parcel shelf - if it has a bubble just left of center for a sub-woofer, you've got premium sound. If not, not likely. I doubt anyone would go to the trouble to change out the parcel shelf. Here's an excellent thread by Jacob Hankins on the premium sound conversion to modern head unit, in case you need it: https://www.jaguarforums.com/forum/x...uccess-195845/
Old Jan 6, 2019 | 11:20 AM
The shallow depth 6 x 9 5th woofer speaker on the parcel shelf I'm working on now
Can't find a X300 5th speaker so trying options ( hint CDMA )
Later I will ad a crossover to drive it but at the fit stage before thenJaguar XJ X350 Rear Alpine Speaker 2r83 18808 BC
is what i'm trying in hand at the salvage yard
Old Jan 6, 2019 | 03:19 PM
cdma's Avatar
I gave up on the Sub. I already have one in the trunk and I just purchased a set of speaker for the doors that kick the bass pretty good and I almost can get rid of the one in the trunk. I can turn the trunk down to 3 or 4 now and it is loud enough. I have two amps in the trunk. One for the stereo and one for the sub. The speakers for the door have a split tweeter/woofer. Put one set of tweeters on the bar that goes by the edge of the windshield and put the other set on the back deck. By the way, I cut a hole on the back deck to let the base come on and put speaker covers over the hole.
Old Jan 9, 2019 | 06:54 PM
96x300's Avatar
I got my kit in and got everything installed today, and I have to say it works perfectly! The radio end is ISO, which fit the Boss head unit, making absolutely no cutting required.
The fascia piece fills up the gaps nicely as well.
My only issue was getting the head unit to fit in the dash, with the extra bit of wiring in the way.. I got it within a 1/2" of clicking into place but it just will not budge the rest of the way... It took several attempts to get that far so for now I'm calling it good!
Actual product names/numbers are
Autoleads FP-14-00 (fascia)
Connects2 CT20JG02 (ISO Harness)
Old Jan 15, 2019 | 06:22 AM
Tbilisi79's Avatar
thank you. I’m trying to do the same thing, but have hard time finding the install kit. It’s not showing in USA. ill try to purchase it from UK. Do you think it’s possible ?
