Supercharger Belt Question
Old Nov 11, 2014 | 10:20 PM
97XJR-Flausa's Avatar
Default Supercharger Belt Question
On my 97 XJR the supercharger belt tensioner came apart today on the highway taking the belt with it. Parts are on order and will be here Friday.
My question is can I drive the car without the supercharger belt on?
I know that performance will take a big hit. My concern is doing any permanent damage to the engine running this way. Unfortunately I need the car to get back and forth to work.
Is there any harm in light driving the car for a couple of days without the belt? Thanks
Old Nov 14, 2014 | 01:14 PM
XJRengineer's Avatar
There is no problem running the supercharged AJ16 engine without a belt. I've covered hundreds of miles like that.
Old Nov 16, 2014 | 09:44 PM
shaune's Avatar
in theory should it be easier on petrol consumption w/o the s/c belt on?
Old Nov 16, 2014 | 10:53 PM
AlbBolivar's Avatar
That's what I thought also but after doing some research, the lower compression ratio without the supercharger boost greatly affects performance
Old Nov 23, 2014 | 04:21 PM
In my experience, removing the SC drive belt improved fuel consumption by about 2mpg (imperial)
Old Nov 24, 2014 | 06:06 AM
OWRltd's Avatar
This is funny as my tensioner seized and melted on Friday. In the past three weeks I didn't like the sound of the belt drives. I sounded off to me. But, I made it to work and had the part on the shelf as I was going to do belts in three weeks. I guess she couldn't wait a couple more weeks.
Old Nov 24, 2014 | 02:30 PM
al_roethlisberger's Avatar
Yeah, similar happened to my tensioner on the Riviera. Squeaked a few times on startup, then seized and ate the belt.
The conventional wisdom on the Riviera Performance board is that once you start to hear the dreaded intermittent pulley squeal.... you have days to get it replaced before it grenades.
silkcat
Jan 18, 2025 04:29 AM
mrplow58
Jan 21, 2024 05:53 AM
Forcedair1
Feb 19, 2020 01:51 PM
Jaiello21
Sep 14, 2015 09:42 PM
raulan
Sep 10, 2015 12:43 PM
