Suspension Help **Thanks**
Old Jan 16, 2014 | 09:33 AM
vandenplas408's Avatar
Default Suspension Help **Thanks**
so i am in the process of making a few tools for my front suspension
first i have a 36' long steel rod 7/8's in diameter with fine -20 thread
i need to cut it into two 18' long pieces.
i tried a drumel and one other tool that i use to grind nails down.
neither worked i endned up cuting like 1/16th of the way threw
would an electric cheap saw work for this.?
next i need to drill a whole in the top of it
do i need a diamond tip since im cutting steel?
im also trying to make a bushing removal tool for the wishbones
im just gonna get a long bolt . 2 washer. 2 nuts. 1 xtra large socket, 1 smaller socket
the bolt will go threw the bushing. on one end where the bushing will be pushed out ill place a big socket so the bushing can fall into it.
on the other side i will place a small socket that wont get stuck when pushed into the bushings place.. ill place washers so the nuts can hold the sockets. ill just tighten the smaller socket side until it push's into the big socket.\
any ideas on how to cut this bad boy
Last edited by GGG; Jan 16, 2014 at 10:15 AM. Reason: edit typo in thread title so it appears in searches
Old Jan 16, 2014 | 10:57 AM
also it says to never re use the spring pan bolts so
what are the length and size replacement ?
i would like to have them before i take them out
Old Jan 16, 2014 | 11:11 AM
damn car i just went out side to check fluid levels and my oil and power-steering are leaking . more diy post to come
Old Jan 16, 2014 | 11:42 AM
AllanG's Avatar
I use a 4 1/2" angle grinder with a cut off disc. Goes through pretty easy. You can get one at Harbor freight for about $20
Can't remember the spring pan bolts exactly but I think they were either M8 x 16 or M10 x16 flange bolts. Use thread locker with them.
tlynch
Dec 31, 2020 01:58 PM
Dutch xjrdiamond
Nov 30, 2019 09:14 PM
dmatthewman
Sep 30, 2015 10:10 AM
ChrisJay
Sep 27, 2015 09:08 AM
