today i will replace outer tie rods, top and bottom wheel bearings.
Old Mar 3, 2014 | 09:42 AM
vandenplas408's Avatar
Default today i will replace outer tie rods, top and bottom wheel bearings.
so i replaced my driver outer tie rod end and i had to bend the threaded part so it could go back in. on other cars i have never had to do that. i normally replace them when they can be easily moved back n forth. i could not get it in with out moving it a little. is that normal for the xj300?
also when i remove the stub axle assembly all i need to do is
remove caliper and set to side
Remove outer tie rod end
remove upper ball joint and separate
remove lower ball joint bolts( bottom of it) and then remove nut and sepperate
this will allow me to pull off the stub axle correct?
Old Mar 3, 2014 | 03:06 PM
i just did the driver side. i took a bunch of pics and everything i will make a diy for
outer tie rod ends
upper ball joint
lower ball joint
inside door handle
just for people in the future do not get EURO SPARE parts
every single one required modification to fit properly
Old Mar 6, 2014 | 10:27 AM
OK today I will finish the other side . My camera died when I was half way done. So ill finish the DIY pic today.
Old Mar 9, 2014 | 09:04 AM
BigBossRadio's Avatar
Thumbs up Thanks for putting this info and DIY together
Hi
Thanks for taking the time and make the post. I look forward to seeing the pics of this. Sorry the camera died........ I'm considering doing some suspension work when the weather clears..
BigBoss in Dalllas TX
BrentGardner
29
Dec 16, 2024 12:13 AM
Doberman_Fan
22
Dec 24, 2019 06:21 AM
rvdz
Dec 7, 2019 06:42 AM
martybmw
Aug 31, 2015 08:41 AM
J-Rock
Aug 25, 2015 08:33 PM
