Torque Wrench Settings
Old Sep 17, 2011 | 06:49 AM
matade's Avatar
Default Torque Wrench Settings
I have a tendency to over-tighten and for that reason, if I don't have a specific torque wrench setting, try to use a short lever. Can be painful but at least it helps to avoid stretching/stripping bolts/nuts.
My current needs are the torque settings for the front seat fixing bolts and seat belt achorage points on my X300 but is there a general torque wrench settings listing anywhere that so far I haven't found.
Many thanks.
Old Sep 17, 2011 | 08:41 AM
caldercay's Avatar
Here's the seat belts ... for some reason, there isn't a torque listing for the seats in the Body Components and Trim section - if I run across it, I'll post
Old Sep 17, 2011 | 10:37 AM
matade's Avatar
That's a great start caldercay. Thank you very much.
Just 30-40, I would definitely have put more than that on them!
Old Sep 17, 2011 | 10:46 AM
aholbro1's Avatar
Some general guidelines: (May be shy of the manufacturer's recommendations, but you shouldn't have to worry about snapping heads if you use them)
SAE:
Torque Table Standard Bolt Sizes SAE - Engineers Edge
Suggested Tightening Torque
Bolt Torque Chart | Portland Bolt
Metric:
Metric Bolt Torque Table - CNCexpo.com
US & Metric Bolt Torque by Grade
Bolt torque specs for socket head cap screws for machine repair assembly bolt torq CNC
Old Sep 18, 2011 | 07:22 AM
matade's Avatar
Originally Posted by aholbro1
Some general guidelines: (May be shy of the manufacturer's recommendations, but you shouldn't have to worry about snapping heads if you use them) . . . .
Many thanks aholbro1. I will need to educate myself on the differences between the different groups but I am sure I will find an answer in these links. Thanks again.
aholbro1
Dec 29, 2024 06:46 PM
mrplow58
Jan 21, 2024 05:53 AM
Broken_Spanners
Dec 11, 2015 04:14 AM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
chatmanx
Sep 11, 2015 07:17 PM
