Transmission Drain Plug
Old Jul 11, 2021 | 04:10 PM
placer61's Avatar
Default Transmission Drain Plug
Hello. I am returning member, but had to re-register. I just picked up a 1996 XJ6. First off, I want to do several drain-and-fills for the trans. I can't get my fat head all the way under the trans pan to get a good enough look, so I am hoping someone here knows what sort of drain plug I have. I see what looks like a thick washer-type plug with a torx or allen head center. It is in the center of the pan. I just want to make sure I have the tools I need before I really shoehorn myself under there for the task. I also don't want to remove something that is not a drain but will harm the trans.
Thanks in advance.
Old Jul 11, 2021 | 06:03 PM
Jagboi64's Avatar
It's a 5mm allen plug. See this procedure here: https://www.jaguarforums.com/forum/x...cement-164781/
Old Jul 11, 2021 | 07:05 PM
aholbro1's Avatar
H5 Allen
https://www.jaguarforums.com/forum/x...-fluid-149399/
Good to find a plug, there....not all were so-equipped and you have to drain by loosening the large nut on the fill tube/dipstick
Old Jul 11, 2021 | 07:07 PM
placer61's Avatar
Thanks, Jagboi. Just what I was looking for.
Old Jul 12, 2021 | 05:29 AM
placer61's Avatar
Thanks for the link, aholbro. Good info.
Old Jul 15, 2021 | 11:37 AM
XJ 4Ever's Avatar
For easy drain and refills, I just like to use a pump through the dipstick tube. No crawling around under the car necessary. Park the car tail up to force more fluid forward, let it sit overnight, then pump away! I emptied into an empty gallon jug, noted the amount taken out, put back in the same, Done!
Old Jul 16, 2021 | 09:25 AM
placer61's Avatar
I just pulled mine up on a couple of 2 X 12 LVLs and was able to get under enough to reach the drain plug. Got about 3 1/2 quarts. Did it 3 times (driving in-between). Should be good for a while.
l3uddha
Jun 16, 2016 11:21 AM
LowellLamb
May 28, 2016 03:56 AM
aviation14
Sep 9, 2014 03:57 AM
Terry H
Oct 18, 2013 04:14 PM
johnsjag
Jul 7, 2008 03:26 PM
