Transmission Shift Override Screw
Old Nov 8, 2022 | 11:05 AM
Parker 7's Avatar
Default Transmission Shift Override Screw
Need the steps to move the shift lever with the override screw on the shift gate plate
Car cranks the starter
4.0 normally aspirated with ZF4HP24
Looking for owner's manual in the meantime
I touched the battery terminals backwards in putting in battery backwards
Not in park switch makes as the key barral lock solenoid clicks and you can rotate the key to get starter rotation
Fully charged battery
Old Nov 8, 2022 | 11:44 AM
xalty's Avatar
remove screw screwdriver in hole
Old Nov 8, 2022 | 11:47 AM
Parker 7's Avatar
Thanks ,
got it and out of park so I can move car for house painting
Thanks for the quick reply in the heat of battle
Maverick115
Jul 30, 2021 11:02 PM
Rhett
Apr 22, 2014 07:16 PM
w1n9m4n
Jun 3, 2012 08:26 PM
solarmusic
Apr 27, 2011 01:13 PM
Boomer from Boston
Feb 6, 2011 05:29 PM
