Turn signals staying on
Subscribe
Dec 20, 2017 | 09:24 PM
Hi,
Whichever way I am turning my turn signal does not turn off.
I was wondering if there is a fix for this and if yes, what is it. Or do I simply replace the stalk.
Thanks,
Jomo
BTW: I searched the forum for this problem but did not find anything
Reply 0
Dec 20, 2017 | 10:15 PM
The turn signal flasher is inside the body processor module or the lamp control module as is goes from the stalk and through both
If you remove the ground in the stalk as it is stuck and it goes out you will prove both modules are OK and the fault is in the stalk switches . This can be done by removing connector CC4
Does the fault accure after you command the switch or all on it's own ?
Reply 0
Dec 20, 2017 | 10:36 PM
Quote: The turn signal flasher is inside the body processor module or the lamp control module as is goes from the stalk and through both
I am fairly sure that it is the stalk. For the turn signal to go on I need to initiate that. After executing a turn the signal does not go off. When I manually move the stalk back to the center position the turn signal goes off.
Reply 0
Dec 20, 2017 | 10:48 PM
error
Reply 0
Dec 20, 2017 | 10:54 PM
Jaguar # LXF6455AA
You will need to take the switch apart to look at the over center mechanism
or
https://www.ebay.com/itm/NOS-Genuine...p/381626997869
cheaper then today's multifuntion switch
Reply 1
Dec 20, 2017 | 10:56 PM
or
OK, I'll look at the switch tomorrow. Does anyone have a picture showing where this spring would go??
Jomo
Reply 0
Dec 24, 2017 | 03:02 PM
Hi,
I got the turn signal switch off today, readjusted the spring and the switch is turning off after left and right hand turns!
Happy Holidays!
Jomo
Reply 1
Dec 24, 2017 | 06:39 PM
Pics to save someone some time and money ?
Reply 0
Subscribe
Currently Active Users (1)
