Tyre Pressure
Old Aug 20, 2011 | 06:44 AM
Car-Nut's Avatar
Default Tyre Pressure
What are the correct tyre pressures mine are wearing thin in the middle on the rear due to wrong pressures I was advised....
Old Aug 20, 2011 | 07:25 AM
Doug's Avatar
Center wear suggests over inflation. I run 32 front/32 rear most of the time, FWIW.
There should be an advisory placard inside the cubby box ld.
Old Aug 20, 2011 | 07:59 AM
Car-Nut's Avatar
Thanks Doug,
I thought about 30-31
Need to source some rear tyres now....
Old Aug 20, 2011 | 09:40 AM
caldercay's Avatar
Depends ... out of my 96 Vehicle Care Manual (cold pressures):
4.0 Normally Aspirated ... 225/60ZR16, 225/55R16, 225/60R16 ...
Max Comfort: Front: 26psi (180kPa), Rear: 28psi (190kPa)
Normal Pressures: Front: 32psi (220kPa), Rear: 34psi (230kPa)
4.0 'charged & 6.0 V12... 225/60ZR16, 225/55R16, 225/60R16, 255/45Zr17..
Max Comfort: Front: 28psi (190kPa), Rear: 28psi (190kPa)
Normal Pressures: Front: 34psi (230kPa), Rear: 34psi (230kPa)
workworkwork
Oct 23, 2015 10:26 AM
280zx-turbo
Oct 2, 2015 02:52 AM
AnD3rew
Sep 26, 2015 06:06 PM
Woznaldo
Sep 26, 2015 11:02 AM
