Upholstery Replacement
Old Oct 20, 2016 | 09:53 AM
95Leaper's Avatar
Default Upholstery Replacement
Been looking for replacement leather seat material for a 1995 VDP but all I seem to find is sets for a standard XJ6. Does anyone know of anyplace making reproduction seat covers for the 95-97 Vanden Plas models? Another Question : How do you remove the upper portion of the seat from the lower portion? I've partially taken a seat apart but can't seem to find any way to separate the two sections. And does anyone know if the top sections are interchangeable between drivers and passengers side seats,as there seem to be many more salvageable passengers seats in the wrecking yards. I would think it might be easier to just remove the upper sections of the seat and swap them over to a drivers seat without having to disassemble the material/foam off of the seat.
Old Oct 25, 2016 | 09:07 AM
JensenHealey's Avatar
Can you tell me where you found the stuff for standard XJ6 cars? The driver's seat bottom in my 1997 is pretty bad and I wanted to see what it would take to get just that recovered or replace it.
Old Oct 25, 2016 | 04:26 PM
95Leaper's Avatar
Try searching on Ebay or just do a google search for 95-57 seat covers. The patterns are the same. All you'll need is you 3-digit trim code on the drivers door sticker. Here's a pair for $300. Not sure if you can just buy an individual seat but you may find the right listing. https://www.lseat.com/products/1995-...FZOKaQodvhcH6w
Old Feb 27, 2020 | 07:40 PM
cdma's Avatar
Anyone every use Lseat.com
Old Feb 28, 2020 | 01:23 AM
Cafcpete's Avatar
They do do VDP covers as well
https://www.lseat.com/products/1995-...ers-front.html
Old Feb 28, 2020 | 05:54 AM
cdma's Avatar
So have you used them and would you recommend them
Old Feb 28, 2020 | 06:50 AM
Cafcpete's Avatar
No, I was just pointing out to OP that the site he was saying only had standard XJ6 covers also did VDP ones.
I did see on a FB site that the colours aren’t great matches, so you want to do both front and back at the same time.
Old Feb 28, 2020 | 07:38 AM
aholbro1's Avatar
I had no need to remove the squab from the cushion, but did skin a driver's seat and recover it. You may find something useful from the event:
https://www.jaguarforums.com/forum/x...lstery-101125/
Old Feb 28, 2020 | 07:56 AM
countyjag's Avatar
Not sure if it helps, but I recently discovered that you can swap the backrests (foam and cover) from passenger to driver side in a matter of minutes with little more then a screwdriver. This enabled me to buy a passenger seat back on line and replace my worn drivers side with it. For the obvious reason, unworn passenger seats are relatively plentiful. I dont know if the same applies to the seat bases but it might be food for thought. My replacement seat back only cost £50, and he had plenty in stock. And of course a UK passenger seat is a US drivers seat.......
Old Feb 28, 2020 | 08:55 AM
Cafcpete's Avatar
Can I ask were you got it?
Old Feb 28, 2020 | 09:38 AM
countyjag's Avatar
from sellerdclc431241(4,599) on ebay
Johnken
Aug 17, 2016 07:01 AM
mattrains
Mar 23, 2011 10:12 AM
xsvjag
Aug 27, 2009 10:30 AM
