Urgent - car dead
Old Feb 25, 2016 | 09:02 AM
David7's Avatar
Default Urgent - car dead
Hey,
I was driving approx 40km/h when the car died, and it wont start. It turns over, but feels like there's no spark?
Replaced fuel filter, spark plugs and air filter last week, if that matters. Car is also converted to LPG, it was running on lpg when it died. It wont start on gas nor lpg though.
Old Feb 25, 2016 | 03:36 PM
RJ237's Avatar
First thing I would suspect is the crankshaft position sensor. Watch the tach as you turn the engine over. Does it read about 200 RPM?
Old Feb 26, 2016 | 12:15 AM
David7's Avatar
I dont think so...
I checked some other threads, and if understand this properly - if it shows 200rpm, you dont know really know if sensor needs replacing - it might, or it might now. But if needle doesn't move at all, it's 100% crank position sensor. Correct?
Old Feb 26, 2016 | 04:12 AM
That is correct.
Also, by your signature, you are past that "magical" 100K mile mark, and for some alien reson these sensors go legs up anytime after that "magic" point, so a good bet in my opinion, and they are not expensive.
The electrical connector for that sensor is also a possible cause, it is vertically mounted, and general crud gets inside the plastic and CAN cause continuity issues.
Very little else on the X300 dies like that little item.
Old Feb 26, 2016 | 08:33 AM
David7's Avatar
So I've ordered the sensor, and then I checked the car again - why does the sensor on my car look so much different from the one in the ad?
This is the one I bought: Jaguar XJ6 XJR X300 Crank Sensor LHE1640AA | eBay
Imgur: The most awesome images on the Internet
This is the sensor, and it doesn't have a connector, instead I have to cut the wires? Is this normal?
Old Feb 26, 2016 | 08:48 AM
JTsmks's Avatar
Originally Posted by David7
So I've ordered the sensor, and then I checked the car again - why does the sensor on my car look so much different from the one in the ad? This is the one I bought: Jaguar XJ6 XJR X300 Crank Sensor LHE1640AA | eBay Imgur: The most awesome images on the Internet This is the sensor, and it doesn't have a connector, instead I have to cut the wires? Is this normal?
The one on your car is someone's jury rig idea of a sensor, the one you ordered is the right one. My original went out at 80k when I went to change out the bracket to "Andy's bracket" it turned to dust. Having seen your picture of what's on your car I'm pretty sure it's your problem. Unfortunately it looks like someone's replaced the "plug" with wire splices.
Old Feb 27, 2016 | 02:27 AM
countyjag's Avatar
I agree, that is not the correct part; looks more like a wheel speed sensor for abs, and not from an X300. Interesting that the car ran at all, and can't help thinking it will run better with the correct sensor fitted.
Old Feb 27, 2016 | 07:07 AM
David7's Avatar
Oh my God...
I decided to go ahead and do a quick search, this is what turned up:
Land Rover Discovery I Defender Front ABS Sensor STC1749 New | eBay
Old Feb 27, 2016 | 07:31 AM
sparkenzap's Avatar
I would say the previous "repair" was made by a pretty good tinkerer! Mechanic? Not so much!
Well, hopefully, he did not have to drill out the hole.
Old Feb 27, 2016 | 12:02 PM
aholbro1's Avatar
If he did, you have a fabulous incentive to upgrade to an Andy bracket!
Old Feb 28, 2016 | 03:42 AM
countyjag's Avatar
On a positive note, at least they fitted a genuine Jaguar Land Rover part!!
Old Mar 1, 2016 | 02:12 PM
iconic's Avatar
The guy that did that fix is worthy of a seat on the 'Pheonix'
....the one with Jimmy Stewart...not the remake!
Old Mar 4, 2016 | 02:28 AM
SleekJag12's Avatar
WTFF???
The "F" appears here as the same basic word in both adjective and noun form.
What a hack! We should have a sticky where we can post real-life stories about how our cars were hacked while in the "careless owner(s)" phase of their history. Of course there would always be a restoration and happy ending to each story. I'm sure we would have many to share, unfortunately!
RobinGa
Nov 13, 2024 01:24 PM
GlynS
Feb 23, 2016 07:00 AM
adenshillito
Feb 14, 2016 11:06 AM
rsmartin
Feb 1, 2016 11:29 PM
Softball60
Jan 31, 2016 01:51 PM
