Urgent help
Old May 12, 2012 | 07:37 AM
spencerikin's Avatar
Default Urgent help
Hi Guys
I urgently need your help.
The car won't turn over today and when I leave the MILs for a bit the ENGINE CHECK, OIL PRESSURE & BATTERY lights stay on. I've used a volt meter on the battery and that's giving just over 12v so I assume that's ok.
The last thing I was doing on it last night was unscrew the four screws around the J-gate to look at the bulbs as I had been looking at a thread on here about changing them to LED's.
I put it back together this morning and dropped one of the screws down between the J-gate and the right hand side and it took me a few mins to fish it out with pilers, but apart from that I'm sure I put it back ok.
But when I go to start her it's like she's not in park properly.
You urgent help is needed and I look forward to it.
Spencer
Old May 12, 2012 | 07:44 AM
Just for the record I go the screw back and screwed it back it. I don't know if the two items are related, just thought I'd let you know lol. X
Old May 12, 2012 | 09:41 AM
KCME's Avatar
Try starting in neutral.
Old May 12, 2012 | 06:10 PM
xjrguy's Avatar
Originally Posted by spencerikin
Hi Guys
Spencer
If you are not really careful, moving the shifter without the illumination module screwed on properly, will wipe the small metal lever right off the micro-switch for Park. Better check that.
Cheers,
Old May 13, 2012 | 02:55 AM
I'm not sure what the technical term is, but I basically removed the metal pin from the plastic slider. All sorted now though :-). S
ManoFlem
16
Sep 25, 2015 09:29 AM
ssshield
Sep 24, 2015 08:29 PM
Peeam
Sep 22, 2015 05:15 AM
Peeam
US Northeast
Sep 21, 2015 09:43 AM
axr383
Sep 18, 2015 11:19 AM
