Ventilation Gate?
Old Jul 19, 2019 | 11:08 AM
Qvhk's Avatar
Default Ventilation Gate?
The AirCon of my XJR is acting weird lately. Often when restarting the engine after a short wait, the centre and side vents blow very warm and humid air, and it takes a while for the vent to blow cold air. Is there something wrong with the ventilation gates or the heater valve is not totally closed? Where to start looking?
Old Jul 19, 2019 | 11:32 AM
Lady Penelope's Avatar
There is a self test on the control panel that will get you started on the path
See page 110
The fault codes are in a TSB
http://www.jagrepair.com/images/TSB/...stem%20DTC.pdf
http://www.jagrepair.com/images/Trai...des/703_SG.pdf
Old Jul 20, 2019 | 10:40 AM
Qvhk's Avatar
Will see if the self-check produce any code. AirCon is often a difficult fix, particularly when most parts are no longer available.
Old Jul 20, 2019 | 11:22 AM
There are ways around parts if it comes to that
The self test does not " show " everything
Old Jul 22, 2019 | 10:07 PM
SleekJag12's Avatar
Aside from a self-test code, there's probably nothing to worry about, Q. You guessed it already. The heater valve is de-energised and hence OPEN when the ignition is off. So the matrix coolant warms up after shutdown. A design characteristic that really wasn't a good one, IMO. Another possibility would be a low a/c charge, which would take longer to overcome the heat and humidity collected by the matrix.
Robinb
37
Jan 6, 2013 09:52 AM
janmagnussen
Jul 26, 2011 02:45 AM
Scubbs
XJ40 ( XJ81 )
May 23, 2011 07:46 AM
chupacabra
Jun 11, 2009 05:11 PM
Oldengineer
Apr 11, 2009 03:48 PM
