Which version of IDS and Mongoose works with X300?
Old Sep 2, 2014 | 04:01 PM
juha_teuvonnen's Avatar
Default Which version of IDS and Mongoose works with X300?
I have IDS 130 and mongoose knock off. Overall the IDS seems to work, except I get an error for all modules when I try to pull the codes:
[ERR 0x22] "The request can not be processed due to a bad specification or missing parameters".
Is there a version of IDS that is known to work with Mongoose for X300 cars?
If there is a VCM + IDS combination known to work, I would be interested in that too,
Old Sep 2, 2014 | 04:15 PM
b1mcp's Avatar
I have a clone VCM and IDS 118.5 and I can confirm that works perfectly on my 95 X300. I've also used it on X308, X Type, S Type, X350, XF and they all worked fine.
Old Sep 2, 2014 | 04:30 PM
Cambo's Avatar
I guess you've seen this?
Mongoose should be OK, I also suspect it's the software installation that might be the issue...
I recall also seeing ERR 0x22 when running my setup in Legacy IDS a couple of times. It's fine when running SDD on modern vehicles, but in Legacy IDS it's "buggy" will freeze or crash from time to time.
If I had one of the older cars I would be looking for a WDS or a PDU system, while the Mongoose is cheap, it doesn't seem to be reliable in Legacy IDS...
Old Dec 1, 2014 | 08:44 AM
aldol's Avatar
what cable do you use?
i seem to undertsand that the mongoose only supports 2005 and up
i also have a 1995 xj6 that was my mom's (RIP)
Old Dec 1, 2014 | 02:41 PM
I have a genuine ford VCM that works fine with ids 118.5. I was unable to get Mongoose clone to work with my 1995 X300.
Forcedair1
Sep 8, 2025 01:57 PM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
philwarner
Sep 5, 2015 10:05 AM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
XJsc-guy
Sep 2, 2015 11:43 AM
