WANTED: Lower NS ATF cooler pipe
Old Mar 18, 2013 | 06:51 AM
theJPster's Avatar
Default WANTED: Lower NS ATF cooler pipe
When taking out my radiator yesterday, I had to cut the lower ATF cooler pipe where it goes in to the rad as the nut was seized solid.
Dipstick and Oil Cooler Pipes-3.2/4.0 Litre-Naturally Aspirated - Parts for XJ Series from (V)720125 to (V)812255 (X300) | Jaguar Classic Parts UK
Part #7.
Does anyone have a spare one available? I'm in the UK.
JP
Old Mar 18, 2013 | 07:32 PM
sogood's Avatar
Part #7.
JP
Saw your other post with all the work you're doing on the subframe etc. I may be able to help as I have a 97 3.2 x300 donor car. I'm away working at the moment and won't be back home at the car until Thursday, and I can take a look see then. Let me know if that's any good to you or if you get sorted in the meantime.
And speaking of "I need a........" I'm looking for two centre caps for the 20 spoke alloys, These are about the same size and shape as a saucer. If you hear of any floating about....................
Old Mar 19, 2013 | 02:40 AM
theJPster's Avatar
As long as it's an auto it should be a match. Only need the nut and a couple of inches of pipe.
The quick test is stick a 19mm on the nut and see if it comes free.
Cheers.
Old Mar 19, 2013 | 06:09 AM
x300man's Avatar
i could help pos have 4.0 ltr at home wich i am scrapping looking at diagram which no. pipe is it have radiator out just need to take other end off i am in york
Old Mar 19, 2013 | 06:58 AM
x300man's Avatar
update, yes if you only need what you say will cut half way along rubber part of pipe if you wish, did not read properly,let me know.
Old Mar 19, 2013 | 12:37 PM
sogood's Avatar
There you go, just like waiting on a bus, then two come along together. I will leave this with x300man for the moment as he's a bit more local, ok? In the meantime folks, I'm still looking for those centre caps................
aholbro1
Dec 29, 2024 06:46 PM
Poet
Oct 6, 2015 09:40 PM
twinstacks
Sep 19, 2015 01:09 PM
Tim Goz
Sep 17, 2015 09:11 AM
chatmanx
Sep 11, 2015 07:17 PM
