water pump
Old Apr 4, 2013 | 12:39 PM
awil's Avatar
Default water pump
How hard is it to change a water pump on a 1996 XJ6?
Old Apr 4, 2013 | 12:59 PM
RJ237's Avatar
Fairly easy, but the bolts can be a little hard to reach. I found it easier to take the air pump off, then back off the tensioner for the alternator. Remember where it was so you can get the proper tension again, unless you replace the belt.
If you check on ebay you can buy a workshop manual CD. It has a parts section and repair including torque settings. Originally from Jaguar Heritage.
Wahooesprit
Dec 23, 2019 02:01 PM
Ozzy_UK
45
Feb 19, 2019 02:05 PM
Ozzy_UK
General Tech Help
Jan 14, 2016 02:52 PM
ksjaguar
Nov 3, 2015 10:14 AM
picard
Oct 12, 2015 11:56 AM
