WDS or IDS for a 97 XJR
Old Aug 5, 2014 | 09:51 AM
sartimowich's Avatar
Default WDS or IDS for a 97 XJR
What will work best for my car?
Old Aug 5, 2014 | 11:24 AM
BlackX300VDP's Avatar
Either will work fine
Old Aug 5, 2014 | 12:10 PM
al_roethlisberger's Avatar
Have to ask "IDS" or "WDS", what is that?
...maybe it will be obvious once answered, and I'm just having a slow brain day
Old Aug 5, 2014 | 09:43 PM
motorcarman's Avatar
When IDS was launched in 2006 we got IDS 42 on a DVD and WDS 42 on 2 CDs.
Then we got IDS 43 on a DVD and WDS 43 as an update to WDS 42 (second CD).
So for a while THEY WERE THE SAME!!!!!!!!!! (I still have DVD copies of IDS 42 and 43)
Then NO MORE WDS CDs were issued and IDS became the only updated system. (IDS DVD101) (I still have copies of 101,102,& 103)
In reality you can use PDU, WDS or IDS as PDU was the system we used when your car was new. WDS was not even introduced until after your car was made.
Good luck finding an operating PDU.
A good working used Ford or Jaguar WDS is probably easy to find. Jaguar software is readily available from many people on this forum.
bob gauff
Old Aug 6, 2014 | 04:29 AM
SleekJag12's Avatar
Originally Posted by al_roethlisberger
Have ask "IDS" or "WDS", what is that?
They are the instruments and software that match the ECU with the Throttle Position Sensor (throttle adaption), and the oxygen sensors (O2 orientation).
If a new TPS is not adapted, a high idle may result. If new O2 sensors are connected differently than the old ones, a misfire may result. That's why those problems sometimes occur when people swap ECUs.
I imagine those tools do a whole lot more too, but that's the extent of my knowledge on the subject! How am I doing Bob?
https://www.jaguarforums.com/forum/x...estion-123314/
Old Aug 6, 2014 | 07:07 AM
[QUOTE=motorcarman;1030500]
[QUOTE]
Bob
When I went to open the new Jaguar West Chester (PA) in 2004, I suggested they have a PDU. Some Jaguar folks agreed and they took one from the training center in Mahwah. I put a battery in it and it worked great! It came with a whole bin of cables and accessories except the old ABS monster tester. I needed that just a couple times though. I think they still have it and for sure one Jaguar tech there knows how to use it if he needs to.
MrWhite
19
Jun 14, 2022 07:49 PM
Marka
22
Sep 11, 2016 12:09 AM
MrWhite
Oct 1, 2015 01:43 AM
JAMES1944
Sep 29, 2015 11:58 AM
N3yyz_XJR
Sep 27, 2015 11:26 AM
