What did you do to your X300 today?
Old Sep 14, 2023 | 09:31 PM
  #1221
944play's Avatar
After refitting an inner tierod boot, attempting to get the outside temp sensor to behave, and wiping up a ton of oily grime from underhood, I took a nice trip to Cascade Locks and over Bridge of the Gods. Trip computer suggests I got 15.3 mpg, the exterior temp did not read correctly, but there are no overnight drips under the engine.
Old Sep 15, 2023 | 01:59 AM
  #1222
watto700's Avatar
I replaced both my boot/trunk support struts as they had grown old and tired after 350,000+ kms and nearly 30 years. One strut I popped straight off the pegs and the other I couldn't get to release so I put my thinking cap on and thought I'd try to unscrew one of the end fittings from the old strut, well it came straight off, and see whether the fittings on the new strut had the same thread. They both had the same thread so I just unscrewed the rod out of the errant stuck inner fitting and screwed the new strut into it.
Presto job done!
Cheers.
Old Sep 25, 2023 | 10:26 PM
  #1223
944play's Avatar
New swaybar bushings in. PS hose u-pipe p-clip replaced.
Attempted a strings-on-jackstands alignment, took out about 1/8" of apparent excess toe in. If it doesn't pass my road test, well, it's going into the shop next week and a real alignment can be added to the services requested.
Old Sep 27, 2023 | 09:19 AM
  #1224
Bill Mac's Avatar
My 1996 X300 6-cylinder is the same colour as John's light blue V12 car.944play
On an excursion a month ago about 80 ks (50 miles) from home I pulled into a roadside park for my wife's toilet stop.
I noticed a burnt oil smell and looking behind the parked Jag I could see a fine oil trail. It was coming from the left side of the engine. The rear end boot (trunk) was covered in oil which had been misting from drops at high speed.
Checked the dipstick and there was just a trace on the bottom. I had checked oil levels prior to departure from home and it was full.
By sheer coincidence another Jaguar driver pulled into the park area and offered assistance, So I asked him to run me to the service (gas)station about 2 Ks away where I grabbed a 5 litre (1 and 1/4 US gallon) container of oil.
I dumped that in the engine which brought it back to full on the dipstick and then drove the car to the centre of this tiny town where there was one hotel, one servo and one post office. At least we were not going to go hungry and thirsty.
Eventually towing was arranged (at vast expense) and the car made it home.
Up on ramps and the culprit leak turned out to be the oil pressure switch. I originally thought it would be the oil bypass housing.
No replacement switches were available locally, but Jagdaim in Melbourne were able to supply overnight. Ordered 2PM arrived 10AM next day.
Three points
I was bloody lucky that the problem was found before running completely out of oil as our destination was another 20 ks further on and it would not have made it .
Jaguar drivers do stick together and help one another.
This is the second time I have run across oil leaks in late model Jag. oil pressure gauges/transmitters.
MY previous XJ 40 was sold to me cheaply because of an unidentified oil leak which turned out to be the transmitter.
Old Sep 27, 2023 | 01:24 PM
  #1225
Parker 7's Avatar
There is an upgraded oil pressure switch part # in I think was a TSB
LNA 5642CA
15-13 (jagrepair.com)
Old Sep 27, 2023 | 07:25 PM
  #1226
Bill Mac's Avatar
Parker thankyou
This 1996 car already has that TSB modification.
I previously had a 1994 X300 without the mod. and yeah, that gauge really showed low on a hot idle.
1994 turquoise X300
Old Sep 27, 2023 | 08:39 PM
  #1227
Parker 7's Avatar
You got the Oh Baby , Oh Baby color I hope to repaint M' Lady Penelope in if I can't salvage the current color that went bad during final stage kidney failure task to recover
The color shows her curves and I have the chrome window trim , chrome mirrors , and hood leaper so other will keep their eye on it as it passes ( or graces the road ) out of veiw
Yeeeeeeeeeeeeea
If you look from the rear she has slight hips as a nod to the series 3 XJ6
Yeeeeeeeeeeeeeea
Scuba diving out of Port Douglas was cool , the rain forest was noisy at night
Old Sep 28, 2023 | 06:32 AM
  #1228
Spud Maat's Avatar
Three points
lucky...
i have a spare oil pressure switch here. i bought one when i was chasing my oil leak, but after replacing the bypass donut rings there was no more leak from there.
but yeah if jagdaim have the stock they are atleast very quick to ship.
Old Sep 28, 2023 | 08:55 AM
  #1229
Bill Mac's Avatar
Parker
I really liked the turquoise colour on the 1994 car. It was unique in this area as there was only one other X300 the same colour.
It was a "sports" model without the chrome bits and no glove box.
I did some scuba diving on the Great Barrier Reef when I lived in North Queensland for 14 years and it is pretty impressive.
You do get used to nighttime noises in rainforest areas. But even when I am now living in a sub-tropical area the wildlife still seems bent on disturbing your sleep.
I sold the 1994 car after acquiring the 1996 car. Attached photo shows one arriving and other departing.
Turquoise 1994 X300 departing. Blue 1996 arriving. Please ignore son's Toyota Ute in the background
Old Sep 30, 2023 | 03:51 AM
  #1230
SleekJag12's Avatar
Lovely ladies. And both with the girl-next-door dimples. Sport dimples were the best. They were n/a in NA.
I recently saw a turquoise 306 on the Bay, and a turquoise XJS on the List in CA. Ou-La-La!!
Old Oct 9, 2023 | 02:12 AM
  #1231
Spud Maat's Avatar
not today but yesterday,
changed the front brake rotors and pads.
RDA GEN 3 rotors
TRW DTEC pads
Old Oct 24, 2023 | 08:09 AM
  #1232
Jcampany's Avatar
Yesterday I fixed the driver side seat belt receiver. - The spring was bent in half. I guess that is why it only worked half the time. Repurposed the spring from the middle back seat receiver.
Earlier this month
  • Fixed the heat - replaced the thermostat, the original was stuck open.
  • Clean ABS sensors all around. ABS light still comes on, must need the module pins soldered. - Haven't built up the courage to remove it yet.
  • Oil Change
  • Debugged the cooling fans not turning on. - Replaced the fan relay via ebay spare parts.
  • Changed the spark plugs
  • Transmission Fluid refresh (still in progress)
Any suggestions on what to tackle next, preventative or otherwise? I picked this car up for my daughter with 90,000 on the clock she would be owner #3.
Old Oct 24, 2023 | 04:10 PM
  #1233
Parker 7's Avatar
The ABS involves the brake switch which is 2 switches in one package
There is a upgraded switch #
Pic coming
PIN / SOCKET 20 OF THE CONNECTOR VEIW
is looking for a car frame ground on movement
aQ
Y
Old Oct 25, 2023 | 10:59 PM
  #1234
Bill Mac's Avatar
Stripped out all of the boot (trunk) panels to get at the SLCM locking module as centre locking was no longer working.
Replacement module is now functioning correctly.
Also needed to find out why the electric aerial is no longer functioning. It was good until a couple of weeks ago.
The aerial turns out to be OK but there is no extension signal coming to the aerial, so it looks like the problem is in the radio.
Note this does not have an original Jag radio. It is running a Pioneer brand. The radio itself is quite good.
I might consider putting the aerial control on a separate switch in the centre console stowage area.
Old Oct 26, 2023 | 11:07 PM
  #1235
Bill Mac's Avatar
X300 Antenna problem
Miracles of modern electronics. That Pioneer radio I mentioned has a tricky little quirk.
Unless the FM/MF receiver function is selected it does not signal the antenna to extend.
You learn something new every day!
Old Oct 30, 2023 | 03:20 AM
  #1236
SleekJag12's Avatar
That makes sense! It is a thoughtful design. My aftermarket Sony always puts the antenna up even though it is not usually needed. So I disconnected the antenna motor to save wear and tear after I had to replace the mast again. But now the FM reception is not so good. I guess I need that manual switch.
Old Nov 6, 2023 | 12:53 PM
  #1237
Jcampany's Avatar
Default Fixed the ABS Error C1095
Finally worked up the courage to pull the anti skid controller to refresh the solder on the power pins. There wasn't a lot of play with my pump so I supported it with a socket to get my hands under it and worked blind with a right angle screwdriver to remove the two T20 torque headed screws. It took a little patience but I got them out. Cut the plastic and made the repair. Put it all back together and gave it test drive. My ABS light stayed off for the drive, it used to come on after reaching 10 or15 mph during the self check. Below are some pictures of the project.
Access hole cut with a Dremel and utility knife
The bad connections
Zoom in of one
Zoom in of the second
Not pretty but end result 1
Not pretty but end result 2
Glued the cut cover back on
Sealed it up with some tape ready for install.
Old Nov 6, 2023 | 05:05 PM
  #1238
watto700's Avatar
G'day John,
Well done. The reason the ABS light came on at around 15mph is that the system does a self test at that speed and also momentarily activates the ABS pump, you might hear it if you listen carefully as you drive off, so the reason you got the warning light was because the pump didn't pass the test.
Cheers,
Jeff.
Old Nov 24, 2023 | 03:38 PM
  #1239
katar83's Avatar
Fitted replacement exhaust boxes, original Jaguar ones. Took about an hour to do both sides.
The right rear one was rotted on the seam and effectively empty inside but had good pipes, the left side had good box but rotted pipes so I've cut off the pipes of the rotten muffler and used them to fix the other one. Should be good as a spare. Replacement are original Jag ones from a 60k miles car and are in excellent condition. The mild steel ones that can be bought everywhere are absolute garbage and don't last more than a few years.
Oh and I think each old muffler had about a litre of water inside. No wonder they rot.
Old Jan 1, 2024 | 04:51 AM
  #1240
Spud Maat's Avatar
Started on a big job today.
got another week off work still so going to put it to good use.
stereo upgrade.
all JL Audio, 12”sub and amp in boot, 6” splits in front, 6” component in rear
also plan to new rear view mirror, front and rear dash cam, footwell lighting and touch up on lots of various little interior trim pieces.
going to be a very very busy week.
my old speakers were toast.
