What is making this noise?
Old Jan 4, 2020 | 03:40 PM
  #41
Todd Wiens's Avatar
Did you find a better price on CD2?
Old Jan 4, 2020 | 08:22 PM
  #42
Don B's Avatar
I haven't had time to search extensively, but my initial search was not promising. The best price I saw was $12.99 per bottle from an Amazon seller. I like CD2 a lot, but Rislone High Mileage Engine Treatment is $4.47 per bottle at Walmart.
Old Jan 10, 2020 | 05:16 PM
  #43
Todd Wiens's Avatar
I managed to slow the oil leak from the right front corner of the head. Replaced the radiator mounts and upper condensor bushings. I also installed the new crank sensor bracket from XJR Engineer.
Put it all back together and the car runs perfectly. Smooth idle. No leaks from the cam cover. Radiator is mounted securely. Volts are where they should be.
I really appreciate everyone's help. Especially Don.
Old Jan 10, 2020 | 06:01 PM
  #44
Don B's Avatar
Hi Todd,
Great work! Your persistence has paid off! Thanks for reporting back. It's always good to hear about a successful resolution.
Regarding your condenser bushings, if your lower ones are shot, you should replace them too. A known issue is that when those lower bushings perish, movement of the condenser allows one of its pipe fittings to rub against a steel braket, wearing a hole in the aluminum pipe and causing a refrigerant leak that can only be resolved by replacing the condenser. If I recall correctly, the only disassembly required to replace those lower bushings is to drop the lower mounting plate, but I may be thinking of the lower radiator bushings.
Cheers,
Don
Old Jan 10, 2020 | 06:54 PM
  #45
Todd Wiens's Avatar
When I got in there, the lower ones were new. I had to replace the condensor last summer.
JayCee
Jan 24, 2017 08:21 AM
Japawels
Jan 20, 2017 11:41 AM
scarbro2011
Jul 2, 2016 05:13 AM
denraden1
Jul 31, 2013 11:21 AM
estunum
XJ40 ( XJ81 )
Mar 2, 2011 08:55 PM
