Where can i find the Diagnostics Port on LHD 1996 XJR
Old Jun 28, 2013 | 09:40 AM
alexcarter's Avatar
Default Where can i find the Diagnostics Port on LHD 1996 XJR
Hi guyz, my car is not starting up and i want to do Diagnostics so where can i find the Diagnostics Port on LHD 1996 XJR and what type of Diagnostics connector does it have?
Many Thanks !
Old Jun 28, 2013 | 09:47 AM
Doug's Avatar
The OBDII port is roughly where the upward sweep of the center console intersects with the lower edge of the dashboard.
Old Jun 28, 2013 | 09:56 AM
alexcarter's Avatar
Many Thanks Doug !
Is there any chance that i will get the Failure code for any sensor when there is no check engine light on?
I bumped into a big hole with my car and the engine started working bad + the black smoke from the muffler.
I hope that there's something with the hose or any sensor that i can connect back because there is no way i can rebuild/fix the engine here in Georgia.
P.S. Now the car won't start at all. I mean it starts if you push the gas pedal till the end and the engine works really bad + the black smoke + there is a smell of gasoline somehow.
Forcedair1
Sep 8, 2025 01:57 PM
D.K
Dec 10, 2023 02:05 AM
XJsc-guy
Sep 25, 2015 11:09 AM
SouthernGypsy
Sep 3, 2015 10:54 AM
