Windscreen Washer Reservoir Replacement
Old Feb 28, 2023 | 06:58 AM
Z55's Avatar
Z55
Default Windscreen Washer Reservoir Replacement
Hi guys,
Anyone knows if a Windscreen Washer Reservoir for the X308 / XJ8 1998 - 2003 (LNC7038CF) will fit my 1996 X300 XJR (LNA7038AA / JLM12455)?
The X300 Reservoir not that easy to find and mine have been damaged at the bottom.
If I remember correctly I've read somewhere that it might work ..? I do see many of the X308 (1998-2003) advertised on eBay and other sites.
Anyone tried it yet?
Thanks in advance.
Old Feb 28, 2023 | 08:47 AM
Parker 7's Avatar
It fits in the same space on the same chassis...between the X300 and X308............
The pump motor and level connectors I think are different.
But the top fill neck is different. But I think the fill neck can swap over as it comes off
But my memory can be bad
A plastic can of weightlifters powdered protein.will fit in there so you might stop by a gym for a empty can
Old Feb 28, 2023 | 11:10 AM
Z55's Avatar
Z55
Thanks Parker,
If the connectors are different I guess it won't work .., if the fill neck can swop out / over I am good with that!
Would like to keep it OEM but the Protein Can might be a last resort or maybe some epoxy?
Regards.
Old Feb 28, 2023 | 01:08 PM
Parker 7's Avatar
Cheaper would be bathtub silicone glue as epoxy can get expensive.
I will look at the salvage yard for a a X300 and X308 and try swapping connectors as they have both
My reservoir was left out when the previous owner had repairs done after a wreck.
I know what you mean on bottom damage as common.
Old Feb 28, 2023 | 03:01 PM
Z55's Avatar
Z55
Thanks Parker,
Bathtub Silicone glue might be an option .., will have a look into that as well.
Down here where I am from there definitely aint too many X300's in the salvage yard! not as fortunate as you guys from the US & UK.
Looks like the 1997-2003 doesn't have as much damage re the reservoirs (bottom) as there are still many availible as "used" on places like eBay.
4dad
Aug 28, 2020 02:47 PM
JezuzNoChill
Aug 27, 2020 11:15 AM
Keesh
Feb 14, 2018 02:06 AM
JTsmks
May 7, 2016 05:45 PM
SkinnyLard
Nov 25, 2012 05:44 AM
