Wing mirrors: loose connections to the door
Old Mar 17, 2014 | 11:58 AM
Rhett's Avatar
Default Wing mirrors: loose connections to the door
For the X300:
Is there documentation on how to tighten the connection between the wing mirrors and the doors themselves? The mirrors are tight at the hinge so the usual fix of tightening the 3 screws from the bottom won't really help me.
The problem is that the whole mirror assembly is loose at the connection to the door but it's not clear from the design how to get to whatever screws or bolts are holding it on. The driver's side mirror shows some slight movement but the passenger side is downright loose.
Help?
Thanks,
Rhett
Old Mar 17, 2014 | 12:14 PM
Rhett,
The mirror assembly is secured with a single Torx (item 14) going through the door frame from the inside and into the mirror bracket:
Wing mirrors: loose connections to the door-x300-door-mirror.jpg
Depending on spec, there will either be a small triangular blanking plate or a speaker on the inside.
Old Mar 17, 2014 | 01:29 PM
Rhett's Avatar
There's a black plastic panel that looks like it's fastened with goop of some kind (picture attached). Should this panel just pull off or do I need to do something more elaborate first? Sorry if this is obvious but I'm afraid of breaking my car.
Attached Thumbnails Wing mirrors: loose connections to the door-x300_behind-side-mirror.jpeg
Old Mar 17, 2014 | 02:13 PM
That does look as if someone has attacked it before!
To remove it safely, the Trim pad needs to come off the door. Here is the Service Manual section:
X300 Service Manual - Front Door Trim Pad.pdf
With the Trim pad removed, the triangular plastic blanking plate can be unclipped from the door frame.
Old Mar 18, 2014 | 10:46 PM
Rhett's Avatar
Thank you. I successfully removed the veneer, the door handle surround, the two screws ans one plastic clip holding on the top panel but it's still firm around the circular air hole.
Does it slide up or to the right or left? Any input?
Thanks again..,
UPDATE: found the little screw hidden under the folds of the rubber seal around the air hole that isn't shown on the documentation. Got it all off, tightened the mirror and it all went back together. Thanks everyone!
99xk8guy
Sep 29, 2025 10:51 PM
Dz1rfj
Jul 17, 2018 10:29 AM
GordoCatCar
Jan 2, 2017 01:10 PM
Dz1rfj
Sep 16, 2015 03:44 PM
sadepol01
Sep 11, 2015 05:26 AM
