Wipers
Old May 20, 2010 | 09:08 AM
rangerdave's Avatar
Default Wipers
Just purchased a 97' XJ6 and have high speed and intermittent for the wipers but no low speed. Is it the motor, column switch, or is there a module/relay somewhere?
Any help will be appreciated!
Old May 20, 2010 | 05:11 PM
bhmaxjag's Avatar
Can't say for sure without proper testing of the components but my money, if going on a hunch, is on the wiper switch. I replaced mine, but for a different reason (wasn't sending pwr to the washer pump). They're not very robust and unfortunately are quite expensive...around $400 new and $180 junk yard
Old May 21, 2010 | 07:35 AM
rangerdave's Avatar
Thanks so much for the reply. Did some additional research and some seem to think it may also be the relays. I am going to replace those first and go from there. Only things left would be switch & motor and as you know, the most expensive.
Old May 24, 2010 | 11:38 PM
panchostatus's Avatar
I'd probably rule out the motor, if the motor was bad, your wipers wouldn't work at all
Old May 25, 2010 | 07:19 AM
rangerdave's Avatar
Default Wipers
Thanks again, I should have the relays this week and hopefully I find the fix. Could certainly be the stalk mounted switch but I am betting on one of the relays...
kingdom worker
Nov 14, 2020 03:47 PM
Ferdie
Nov 26, 2018 05:42 AM
sg997tt
Oct 9, 2015 10:57 PM
davidboger
Oct 1, 2015 10:13 AM
