Wipers not working correctly.
Old Oct 13, 2022 | 04:12 PM
Spud Maat's Avatar
Default Wipers not working correctly.
Ok so driving to work today and it started raining, i switched the delay on, and it was working, it started raining heavier so i flicked it to speed 1 and they stopped working. Then i flicked it to speed 2 and it worked. Flicked tit back to 1 and not working. Then out to delay, not working, clicked stalk back for one pass, not working, squirt water, water works, but wiper did not move.
currently my wiper does not work on speed 2 and do not return to park position
squirt - water but no swipe
once - not working
delay - not working
Speed 1 - not working
speed 2 - working
this must be an issue in the switch mechanisim?
if it was fuse then nothing would work as only 1 fuse.
could it be relay?
Have not got a chance to
check wiring diagram to see exactly how the relays work until i get home
Old Oct 13, 2022 | 04:29 PM
motorcarman's Avatar
Remove/check the wiper SPEED relay behind the headlamp.
I've seen this enough time at the dealer to recommend investigating the relay.
Old Oct 13, 2022 | 04:57 PM
Spud Maat's Avatar
Yeah actually that makes perfect sense. Relay stuck open or closed, meaning only one speed available
Old Oct 13, 2022 | 08:50 PM
Parker 7's Avatar
There is a history of the switch wires coming loose from there sodier connections there are pictures from others , just resodier
There is also wires rubbing in the column
The easiest and first try is 2 wiper relays that you can swapped with other then each other , I would target # 6
See also
Crazy Wiper Problem - Jaguar Forums - Jaguar Enthusiasts Forum
Old Oct 14, 2022 | 01:27 AM
Parker 7's Avatar
The slow / fast relay has a fuse # !6 / 10 amp right heelboard fuse box which relies on the fuse box relay staying closed
This is the same fuse box relay that must stay closed to keep fuse # 10 / 5 amp right heelboard fuse box powered which is the control half of your fuel pump relay
notice the engine correlation ?
You can have a floating relay
in all fuse boxes fuse 10 , 12 , 14 , and 16 must have the fuse box relay closed
fuse 1 - 9 and the rest bypass this fuse box relay and are directly wired inside the fuse box to the battery
Old Oct 14, 2022 | 02:35 AM
Spud Maat's Avatar
thanks for the info....
but fortunately it was the easy option.
it is the wiper relay.
swapped out a known working relay to test.
all functions worked.
now i guess i need to go buy a relay unfortunately don't have any spares atm.
jsduggan
XK120 XK140 XK150
Aug 1, 2019 05:03 PM
jsduggan
XK120 XK140 XK150
Aug 1, 2019 04:54 PM
03s-type_sport
Jan 25, 2017 06:28 PM
manycars
Nov 21, 2015 08:46 AM
kiloslanga
Mar 16, 2008 09:52 AM
