Won't start
Received 12,767 Likes
Hi CartF1,
It would help us to know if the cranks-but-won't-start condition came on gradually or suddenly, or if the car had not been started for some time.
In addition to Lady P's good advice about the fuel pump, probably the most common cause of cranks-but-won't-start is low battery voltage. If the voltage sags much below 11 volts while cranking, the Engine Control Module (ECM) will not trigger the ignition to fire.
Another common cause is failure of the Crankshaft Position Sensor (CKPS). A simple check is to watch the tachometer/rev counter while cranking the engine. If it reads approximately 200 rpm while cranking, the CKPS is probably providing a plausible signal to the ECM. If the tachometer reads 0 rpm, suspect the CKPS or its wiring. Sometimes simply cleaning the tip of the sensor and the teeth of the reluctor or sensor ring on the crankshaft will restore proper operation.
Another possibility is water in the petrol. Had you recently refueled?
Cheers,
Don
Cheers,
Don
The following 2 users liked this post by Don B:
93SB (05-10-2018),
MountainMan (05-09-2018)
euphonium01
06-02-2018 01:42 PM
mrkaine
17
11-22-2016 01:06 AM
82WingNut
10-21-2016 05:57 PM
JimC64
03-02-2015 08:07 PM
