x-300 keyless entry
Anyone know where I can get a used keyless entry remote for my 1996 VP?
The dealer price is over $300.
And what about the frequencies used on those remotes?
Many thanks.
bliving7-Jag owner since 1982 but new to the forum
Many thanks.
Fairly common on Ebay for $75-$100
At some point Jaguar changed frequency from 315Mhz to 433Mhz. I can't remember the breakpoint.
I think the antenna (imbedded in the back glass) configuration/appearance will identify which you need....but we'll have to wait for someone with a better memory to come and explain exactly what to look for
European frequency is always 433Mhz. I thought US frequency is 315Mhz.
Have you found instances of 433Mhz remotes working on a US Jaguar?
My understanding is that the change to 433mhz applied to all cars regardless of market.
Posting #4 in this thread has a tech bulletin discussing frequency change and antenna identification
https://www.jaguarforums.com/forum/x...-remote-62245/
Doug,
Thanks for that information and useful link. That's dispelled a long held misconception for me!
Checking the Parts Manual across the model range, I see that 315Mhz is now only applicable to Japan and South Korea.
Graham, yes you are right,Japan and Korea use 315.My x300 was bought here and after messing around trying to get the fob to work i just bought the fob from US and changed the transponder unit to 433 and all is well
All those TSBs are in the large file section. I uploaded a bunch of older ones years ago.
Do a search of the info, read them all and most people will probably ask so few questions that this forum would be a quiet place.
Unfortunately it takes hours and most people just want a quick answer.
I guess we live in a 'microwave' society (I want it NOW) kind of like a fast 'google search'. It would have taken YEARS if it was like the old 'go to the public library days'.
Now we find all sorts of info in seconds.
bob gauff
bob gauff
Did your dealer check the security module ? You can not rely on the rear windscreen circuit as they work equally on both 315 and 433. Save yourself some time and money and pull out the module and check for yourself. It is a little awkward to get out but worth it as key fobs are 60 to 80 dollars a shot on ebay.It is up by the fuel filler in the trunk and is held in place by two bolts,remove the carpet to get to it.
Wolfy
May 28, 2024 08:06 AM
