X300
Old Aug 19, 2019 | 08:18 AM
Lewis1805's Avatar
Default X300
It's my first time on here so please bear with me on this
Text you copy will automatically show here
Any one tell me what size socket you need to remove the oxygen sensor on an xj6 x300 1996 model
Old Aug 19, 2019 | 09:37 AM
Lady Penelope's Avatar
I can't remember the size but is important not to twist the wires , I think are 17 mm and the treads are 12 mm . A - ha .........I nailed it again
https://www.ebay.com/itm/Oxygen-Sens...-/232513083877
They are galvanized wires iin this application and brittle
The X300 on the AJ16 engine are different O2 sensors as they are titanium and generate a different resistance to alter a reference voltage
See page 80
http://www.jagrepair.com/images/Trai...20-%202000.pdf
There is a cheap connector ready substitution as the Bosch # 13789
Some have found the connectors crossed as they will fit the same connection , this effects engine regulation
On the car side of the connector you will find the wire colors the same with the exception of the 4th wire being Blue , Red , Green , or Brown
The aft sensor connectors can get some corrosion on this sensitive O2 signal as well as the overlooked important engine wiring grounds
The Papa Indy 61 connector is common to get corroded and is addressed in a Jaguar TSB
You will see it as the White / Green wire in the pic as the lower row in position # 12 , this is my first Jaguar , I'll have to work on that
BobbyDing
Feb 25, 2019 07:11 PM
Boeingtravel95
Jan 29, 2019 04:14 PM
JensenHealey
Feb 25, 2018 08:22 AM
95Leaper
XJ40 ( XJ81 )
17
Feb 26, 2017 08:27 PM
Angelo Meyers
Dec 9, 2012 05:00 AM
