X300 3.2 aircon compressor
Old Mar 12, 2019 | 09:14 AM
kamera's Avatar
Default X300 3.2 aircon compressor
Hi guys
I'm trying to find a replacement AC compressor for my x300 3.2. The part number should be MNA7300AB. However, I tried looking up ebay and found out there are different compressors for different models - 4.0, 6.0 etc.
Do you guys have any sources on a good (aftermarket) compressor? Doesn't have to be genuine jaguar one as it's quite expensive. I recently found an aftermarket one (don't know the manufacturer) in Australia but it's still not cheap - USD400. Or perhaps I can get a Denso one?
Old Mar 12, 2019 | 10:49 AM
Lady Penelope's Avatar
Look on the compressor for the Denso part number
Off the top of my head is a 10PA17
https://www.shopcenturyautoair.com/s...mpressors.html
The website also has clutch coils other the replacing the whole clutch as well as the main compressor bearing
Once you have it apart you can see if you have a broke piston rod
The engine will run fine without the AC belt during repairs
The AC belt idler pulley long adjustment bolt can be frozen with rust so the whole assembly can be removed to free up the bolt on a bench
There is a self test on the X300 AC control panel before taking the AC system apart
http://www.jagrepair.com/images/TSB/...stem%20DTC.pdf
The dryer is recommended to be replaced $ 35 US , how old is yours ?
dhrudge
Jun 15, 2017 01:26 AM
john_cook12
Aug 10, 2016 11:37 AM
NathanDD6
Feb 23, 2016 07:07 AM
RoyJ
Jan 13, 2014 12:56 AM
steventoon
Nov 12, 2013 11:31 AM
