X300 3.2 won’t rev ?
Old Mar 15, 2026 | 04:05 AM
Stu Jags's Avatar
Default X300 3.2 won’t rev ?
Rusty my well traveled x300 has developed a fault during her winter rest. Was perfect when parked up three months ago now won’t rev passed 1200rpm. Starts and idylls perfectly but as rev builds it’s like she floods herself with fuel. Any ideas appreciated, I’ve tried what I can think of.
Old Mar 15, 2026 | 12:13 PM
Parker 7's Avatar
Short term fuel trim as it climbs through revs . Target 0 %
The 1 fuse for all O2 sensors internal heaters to read correctly , either as only 1 # 10 , 12 , 14 , or 16 right engine bay fuse box
MAF connector still attached middle wire on paper 1.2 volts DC at proper idle speed this value climbs toward 5 on throttle up
TPS connector still attached 0.60 volts DC at the idle stop , climbing toward 5 on throttle up . No opens on this variable resistor as you very very slowly bring throttle up ( engine does not need to run )
This TPS connector hidden can be read as it passes over the fuel rail if you knick the wire or at the ECU connector as pin X and Y but reading the resistance value again . not seeing an open
Old Mar 15, 2026 | 01:08 PM
Stu Jags's Avatar
Default Fixed her
I thought about it over a cup of tea. It had to be something affecting whole engine, not just one cylinder as if just one cylinder engine would still be able to rev. It was faulty when hot or cold, so couldn’t be O2 sensors as they are out the equation when cold. It wasn’t the MAF sensor as that was working. Only other thing could be crankshaft sensor! Took it out, replaced for a spare I have had for years and hay presto she was fixed
Old Mar 15, 2026 | 01:45 PM
Parker 7's Avatar
There has been recent talk on cheaper CKPSs even though is a generic part and not Jaguar specific
Someone found grime on the sensor face looking at the spinning target and one even had a extra ( now 2 instead of original 1 ) missing tooth broke off removing the harmonic balancer using alternate method ( jamming large screwdriver on existing teeth that need to stay to lock crankshaft / tooling of sorts )
Keep a spare jumper for the fuel pump relay as that single CKPS signal can fail in the fuel pump enable aspect
If I recall you had a CKPS wiring issue in the past
Old Mar 16, 2026 | 02:37 AM
SleekJag12's Avatar
A silly little broken CKPS is not gonna keep Rusty down for long! Nice work, Stu, go for the #1 easy things first. I think I should drink more tea.
fab88
Jul 23, 2024 04:50 PM
fab88
Jul 22, 2024 02:17 PM
Winalot
Jun 22, 2021 04:33 PM
280zx-turbo
Jul 3, 2015 09:05 AM
280zx-turbo
Jun 28, 2015 06:07 AM
