X300 Door Panel clips
Old Jun 20, 2022 | 10:55 AM
Winalot's Avatar
Default X300 Door Panel clips
Hi
After having read lots of threads on front door panel removal, I think I am ready to have a go. One piece of advice I have read many times is that the clips ( Christmas Tee Clips is it?) that they will break inevitably, and it would be wise to order a few spares.
Does anyone know where I can get some, and what they are officially called, part numbers etc.
Hope someone can help.
W
Old Jun 20, 2022 | 04:30 PM
olivermarks's Avatar
https://www.partsgeek.com/gbproducts...hoCZUIQAvD_BwE
Old Jun 20, 2022 | 08:42 PM
watto700's Avatar
G'day Winalot,
You can get special tools for removing upholstery clips, they look a bit like a narrow blade with a slot in the end. See the pic below
You slide the blade between the door panel and the door with the slot around the fir tree part of the clip and you should be able to lever the clip out without breaking them.
Cheers,
Jeff
Old Jun 21, 2022 | 04:08 AM
Winalot's Avatar
Thank you both, got even bigger problem, just posted help needed, can’t open trunk cos battery completely flat.
W
Old Jun 21, 2022 | 05:55 AM
Redlock's Avatar
I have a loose door card which requires new clips. Is there a UK supplier?
Old Jun 21, 2022 | 08:42 AM
Winalot's Avatar
What about an ordinary household fork bent open, and cut down a bit. Would that do?
Old Jun 21, 2022 | 11:03 AM
Winalot's Avatar
Well got it all off, I didn’t break any clips but 4 were already broken and still attached to the door. I can’t see how they fix to the door panel! They must have a loop which clicks onto the little bar in the cutout?
could they not be epoxied into the space, 1 appears to be allready.
Without taking another good one off can’t see how they fix.
Old Jun 23, 2022 | 09:48 AM
Winalot's Avatar
Answering my own question, yes they epoxied back in quite well using liberally around the edges. Worked fine, until I need to remove another time, but for moment ok.
W
jacklynthejag
Jan 13, 2018 03:00 AM
stanislav
Nov 13, 2016 04:29 PM
SparkyGage
Jun 23, 2015 11:13 AM
mike99910
Feb 12, 2014 09:47 PM
TopHatChef
Jan 2, 2012 09:17 PM
