X300 Heated Windscreen Connector Location?
Old Mar 22, 2015 | 12:46 AM
FrozenApple's Avatar
Default X300 Heated Windscreen Connector Location?
I'm curious about the front heated windscreen harness connector is at? currently my front heated windscreen barely works, i suspect its due to corroded connector.
Does anyone know the exact location of this connector is at? is it behind the A-Pillar or...?
Old Mar 22, 2015 | 04:44 PM
Jagboi64's Avatar
The connector is at the base of the windshield, in the engine bay. You might have to remove the plastic trim piece that goes under the wiper arm to see it. You'll see 2 heavy wires at each bottom corner of the windshield, follow those and you'll see the connector. By memory, the wire from the windshield is about 10" long and then it joins the body harness.
I believe there are relays for the windshield too, once for each side ( the circuit is split in half, dividing the windshield heat into right and left sides). It draws a lot of power, make sure the alternator is up to scratch and the belt is not slipping. It helps to rev the engine a bit too, mine used to have the voltmeter drop when I turned the windshield on at idle
Old Mar 22, 2015 | 05:03 PM
Thank you! i will check if i can get to it later this week. I do believe my is corroded or something, only a few line works on both sides or is it?. there are no visible damage to the windscreen, is there other reason why it would cause such problem?
Old Mar 29, 2016 | 01:22 PM
trevor24's Avatar
Hi I have a windshield which is not heating at all, it may be the screen itself, anyhow I would like to check all possible problems in the hope of getting it going , is there a check list of possible causes, ? I'm a complete novice but I'm making progress!!! Any suggestions would be greatly appreciated thanks
Old Mar 29, 2016 | 01:29 PM
trevor24's Avatar
Hi I have a 98 xj8 which is not heating at all on the windshield, is there a list of possible causes that I could get through in the hope of getting the heater to work again, I'm a novice but I'm making progress ! Many thanks
Old Mar 29, 2016 | 06:59 PM
Jagboi64's Avatar
You could unplug the screen connectors and check the resistance across the screen wires. Should be a few ohms, if it's open circuit then you have a defective screen. Could also be a bad relay. I'm not sure if the X308 has those or not, but they do fail.
Old Mar 29, 2016 | 07:10 PM
trevor24's Avatar
thanks i will check it out as soon as i can, trevor
aholbro1
Dec 29, 2024 06:46 PM
Forcedair1
Feb 19, 2020 01:51 PM
cissdm
May 3, 2016 06:02 AM
copyman01
Nov 1, 2015 01:01 PM
jagent
Sep 12, 2015 09:10 AM
