X300: Help! Cannot be started
Old Apr 12, 2024 | 10:03 PM
fab88's Avatar
Default X300: Help! Cannot be started
Good morning,
Here is my concern;
- A friend came yesterday with a "suitcase" and plugged it in
it has seen a defect (temperature sensor), it therefore to delete it
and since;
- Unable to start car
When I put the contact, all the lights light up then turn off
and
I turn the key
and there:
- Nothing, no noise and no start
moreover
after I can’t remove the key,
I am obliged to disconnect the battery to release it
The boating is new
Thank you all for your help as my current fortune does not allow me to go to the Jaguar Garage!
Old Apr 12, 2024 | 10:49 PM
Parker 7's Avatar
No starter rotation ?
IF STARTER DOES ROTATE
The OBD 2 port has a power wire that shares the same fuse that controls the fuel pump relay , fuse # 10
Someone found a bent pin in the OBD 2 port
Old Apr 12, 2024 | 11:00 PM
fab88's Avatar
I don’t think the starter is spinning
because no noises at all
(as if the battery was removed)
and then I can not remove the key, force to disconnect the battery for this
before putting this "suitcase" the car demarrais well!
Old Apr 12, 2024 | 11:05 PM
fab88's Avatar
where is the
Hellboard RH? fuse box and 10 fuse?
Old Apr 12, 2024 | 11:10 PM
Parker 7's Avatar
Does the starter solenoid relay ( large # 4 left ) click with your finger on it and not sound as there are other clicks going on in the area , this splits the starter rotation issue in half and other system issues will work on later
3.2 liter engine ?
Old Apr 12, 2024 | 11:14 PM
Parker 7's Avatar
Voltage Gauge , does the voltage sag on starter engagement ?
Old Apr 12, 2024 | 11:35 PM
Parker 7's Avatar
Rear seat right side behind the passengers' ankles
The # 1 ( one ) fuse is closest to the large terminal post on the fuse box
Old Apr 13, 2024 | 12:10 AM
Parker 7's Avatar
To ensure you have power to all points of the car
Have key in run position but engine not running
Remove the relay in the corner of each 5 fuse boxes with the exception of the left engine bay fuse box
The relay should click in your fingertips
The left engine bay fuse box relay is a swapping option , only runs the car horn
Old Apr 13, 2024 | 03:54 AM
Cafcpete's Avatar
If ALL the lights went off, including engine management, then isn’t it immobilised?
It might be worth using the fob to lock unlock the doors as that sometimes resets the security module.
If that fails then your friend may have reset more than he intended and you may need to re attache the key to the car!
You could try wiggling the gear stick in case the park switch is temperamental, I can see the key not coming out if the car didn’t think it was in park.
Old Apr 17, 2024 | 03:48 AM
fab88's Avatar
Re Bonjour
Sorry for the moment I can not take too much care of my Jaguar x300
I’m "nailed" to bed with bad flu
But I still call Garage Jaguar
and they can of course if I bring the car
look at this defect
this around May 15th and of course at the price of 150th/ hour
I keep you informed as soon as possible!
Old Apr 17, 2024 | 03:50 AM
fab88's Avatar
je signale bien sur que la voiture ne roule pas (elle est en stationnement)
Old Apr 22, 2024 | 06:04 PM
fab88's Avatar
Re Bonjour,
Well here’s the problem is solved
indeed, I contact the seller, who repairs from time to time Jaguar,
this one tells me to do;
- disassemble battery and put lug + and lug - in direct contact
I hesitated, but after doing it and waited about 30 seconds
The car is restarting...
So thank you all for your help and see you soon on our roads!!
Old Apr 22, 2024 | 06:06 PM
fab88's Avatar
at first the key still did not withdraw
I maneuver the livier of speed
and there ok everything is "return " in order!
Old Apr 23, 2024 | 08:25 AM
Cafcpete's Avatar
Thank you for the update!
jagxjr
28
Feb 26, 2024 07:28 AM
Sheaff
Nov 7, 2023 08:09 AM
mjgrossheim
Apr 8, 2014 12:43 PM
chokeu2
Feb 17, 2011 09:37 AM
BlueJagster
Jun 30, 2009 04:17 AM
