- A friend came yesterday with a "suitcase" and plugged it in
it has seen a defect (temperature sensor), it therefore to delete it
and since;
- Unable to start car
When I put the contact, all the lights light up then turn off
and
I turn the key
and there:
- Nothing, no noise and no start
moreover
after I can’t remove the key,
I am obliged to disconnect the battery to release it
The boating is new
Thank you all for your help as my current fortune does not allow me to go to the Jaguar Garage!
Does the starter solenoid relay ( large # 4 left ) click with your finger on it and not sound as there are other clicks going on in the area , this splits the starter rotation issue in half and other system issues will work on later
If ALL the lights went off, including engine management, then isn’t it immobilised?
It might be worth using the fob to lock unlock the doors as that sometimes resets the security module.
If that fails then your friend may have reset more than he intended and you may need to re attache the key to the car!
You could try wiggling the gear stick in case the park switch is temperamental, I can see the key not coming out if the car didn’t think it was in park.
Re Bonjour
Sorry for the moment I can not take too much care of my Jaguar x300
I’m "nailed" to bed with bad flu
But I still call Garage Jaguar
and they can of course if I bring the car
look at this defect
this around May 15th and of course at the price of 150th/ hour
