X300 intermittent engine stop
Old Jan 25, 2016 | 02:00 AM
Atco's Avatar
Default X300 intermittent engine stop
I bought a 4.0 Daimler Century last year. Previous owner said occasionally the engine just stopped for no reason. I drove it home & the next day drove to Suffolk & back. Total 300 miles, no problem. I put it down to lack of use! The problem then appeared. Starting from cold left ticking over it would sometimes stop. More alarmingly it would stop at a road junction or roundabout so coasting to a giveaway/yield sign when applying the loud pedal the engine would just stop. Sometimes the revs would just dip to around 500rpm and it would recover. After stopping sometimes the gearbox fault light came up and then it went into limp mode, no top gear, no kick down etc. MOT failed on emissions. MAF sensor changed as I had a spare & it passed. The heater pump failed the other day and to replace one of the mountings I had to remove MAF sensor and plastic inlet duct to the inlet manifold. I discovered the rubber bellows between duct & manifold was damaged/split. I have changed it and although I have only done 120 miles since I think the problem is cured.
Hope this helps someone
Kind regards
Charles
Old Feb 3, 2016 | 07:15 AM
Malihide's Avatar
If the problem comes back at junctions, swap out your IAC valve.
Congratulations on owning such a beautiful car. The Century alloys are probably my favourite wheels of all time; I'm jealous!
Old Feb 3, 2016 | 02:14 PM
iconic's Avatar
I think this issue is getting more common as the X300 fleet ages, the bellows are getting to that age now and perishing...
Well spotted
Old Feb 4, 2016 | 07:55 AM
Atco's Avatar
Thanks guys and for the comment on the Century. I have never actually seen another one in the flesh!
Pristine97XK8Convertible
Dec 17, 2015 11:52 AM
kamalislamof
Dec 15, 2015 09:06 PM
tarheel72
Dec 11, 2015 10:25 AM
Spinedoc2304
Dec 11, 2015 09:30 AM
baal
Dec 10, 2015 04:32 PM
